社群
Revision as of 12:58, 17 January 2018 by S2KTS (talk | contribs)
Community | Wiki Administration | Help and support
RepRap社群資訊站
歡迎光臨RepRap(瑞瑞波)社群資訊站. 本資訊站提供您有關RepRap(瑞瑞波)專案的最新消息. 您可以跟RepRappers(瑞瑞波人)保持聯絡, 學習如何分享有關RepRap(瑞瑞波)的消息及各地RepRap(瑞瑞波)的活動.
開始進入
網路講堂IRC
IRC #RepRap 眾多的瑞瑞波人都聚集在freenode講堂.如果您想找一些同好,網路講堂IRC是您不可錯過的地方.
如果您不熟悉網路講堂IRC,使用瀏覽器直接輸入http://webchat.freenode.net/?channels=reprap 即可進入網路講堂IRC.
社群論壇
RepRap論壇 瑞瑞波人的第一手報導及RepRap事件簿. 許多瑞瑞波人都在此保持聯絡並協同作業.
本地使用者族群與黑客空間
Of particular interest for new RepRappers is the RepRap User Group forums (RUG論壇) 提供了本地RepRap用戶的基本資料. If you are looking to find local help building a RepRap your local RUG 論壇 or hackerspace may be the best place to start.
There are also RUG wiki pages available for some of the RUGs, although many of these are incomplete.
尋求幫助
Development
The RepRap 專案 is 社群 driven so helping out can be as simple as making a new extension and blogging about it or posting it in the Development Catalog.
Official software and hardware sources are stored on the RepRap Sourceforge SVN. If you wish to contribute a patch or bug report the RepRap 專案 uses Sourceforge's issue tracker or you can contact Adrian directly if you are interested in gaining commit access although generally the issue tracker is a much faster route to having your patch accessible.
Documentation
Lets face it, the documentation is sloppy and you've probably got some ideas on how to fix that. Go for it! This mediawiki is open to edit, if you run into troubles or aren't sure how to edit the pages you see here check out the help page (although that page is also a bit of a mess.. seems a bit of a cyclic problem).
You can find more info on the RepRap documentation and the tasks that need be done at the Wiki Administration portal.
There is also potentially some interest in doing some RepRap Collaborative Publications however it might be best to ask around on IRC or the 論壇s to see if anyone is currently interested.
In particular, many people think it would be a wonderful thing to simplify the design and document the design in enough detail that a couple of 13-year-olds could build a RepRap: education.
Donations
Donations are always appreciated and go towards helping out the RepRap Dev Team
部落格與同好
RepRapper部落格
瑞瑞波長老
  • Admins consist of active members in the RepRap 社群 that run the server, organize releases, review the documentation and - often as not - design parts of the RepRap machine and its software.
  • RepRap contributors can also be found on the Acknowledgments page
其它同好
