3DPrintMi
Revision as of 02:36, 21 January 2015 by Gyronictonic (talk | contribs)
3DPrintMi - Print. Make. Innovate.
Open Frame Reprap
Introduction
3DPrintMi combines the minimalistic, open frame style of the Printrbot/Wallace with the fixed Y Gantry system of the Mendel. The printed parts are designed to be produced rapidly, efficiently and assembled easily.
The primary goal for this printer was to incorporate the maximum number of printed parts, thus enabling self replication. Built from the ground up, this RepRap requires very little tooling and does not need specially made parts (e.g. lasercut pieces) for it to function.
In 2013, the 3DPrintMi was awarded third place in the Uplift Interim Personal Manufacturing Prize aka Gada Prize.
Specifications
3DPrintMi Mini
  • Total Cost: $281+
  • Material Cost
    • Printed Parts: $20 ($0.3 per cc) about half a spool
    • Hardware: $105+
    • Electronics: $156+
  • Printed Parts: 33 (37 with extruder)
  • Non-Printed Parts: 279
  • Printer Dimensions: 38cm x 43cm x 41cm (15" x 17" x 16")
  • Build Area: 152mm x 152mm x 200mm (6" x 6" x 8")
  • Accuracy: 0.15mm
  • Speed: 80mm/s perimeter, 110mm/s infill
  • Units of Measurement: Metric
3DPrintMi Plus
  • Total Cost: $308+
  • Material Cost
    • Printed Parts: $22 ($0.3 per cc) about half a spool
    • Vitamins: $130+
  • Printed Parts: 37 (41 with extruder)
  • Non-Printed Parts: 295
  • Printer Dimensions: 43cm x 44cm x 45cm (17" x 17.5" x 18")
  • Build Area: 20cm x 20cm x 20cm (8" x 8" x 8")
  • Accuracy: 0.15mm
Aluminum 3DPrintMi Plus
*Total Cost: N/A
  • Material Cost
    • Printed Parts: N/A
    • Vitamins: N/A
  • Non-Printed Parts: N/A
  • Printer Dimensions: N/A
  • Accuracy: 0.15mm
Videos
Assembly of the 3DPrintMi
<videoflash>9lfONhUdHPo</videoflash>
My first RepRap printing the 3DPrintMi
<videoflash>7hH3ASi5rJ0</videoflash>
3DPrintMi printing the [Tree Frog by MorenaP]
<videoflash>jkWKzN3Rvwo</videoflash>
Printrbot+ and his son (my first RepRap, father of 3DPrintMi) printing together
<videoflash>C-fGKSsrgCo</videoflash>
Features
  • In compliance with Vertical X Axis Standard, compatible with Mendel style X gantry
  • Fully printed Y carriage platform
  • Extruder mount compatible with Wade Extruder/Bowden or Direct Drive(QU-BD MBE)
  • Adjustable frame allows increased build volume (Working)
  • Fully parametric
  • 56% Plastic, 44% vitamins (Volume)
Additional Info
  • Estimated assembly time = 2 - 3 hours (excludes electronic/board assembly)
  • Estimated total print time of a printed set = 28+ hours
  • Estimated total plastic usage of a printed set = 370 cc @ 60% infill
  • Power requirement = 80W to 100W (Hotend @ 240C, Hotbed @ 95C)
Documentation
Future Development
  • Design a new Y Carriage to retrofit a LC build platform as an alternative to the printed Y Carriage.
  • Optimize parts to cut down plastic usage without compromising frame rigidity.
  • Fishing line for linear drive
  • Create a LC assembly board template to speed up assembly time. No need to measure with caliper during construction.
