3d printer nelu
Revision as of 17:02, 24 June 2015 by Altnelu (talk | contribs)
3d Printer Nelu
Release status: Working
3D printer nelu
GPL
3d Printer
under construction
3D printer nelu type printer is a nonlinear delta robot to remove the rods and linear bearings. Objective: Make a cheap printers as easily available parts.
Inspired by:
http://reprap.org/wiki/Delta
https://hackaday.io/project/1565-icepick-delta
https://hackaday.io/project/963-firepick-delta-the-open-source-microfactory
Materials used:
- M8 threaded rods. (3 pieces of 1M)
- Nuts M8
- 608ZZ bearings (6 pieces)
- PLA
- Copper pipe with outer diameter of 6 mm and 4mm inside the extruder
- Brass nut clogged nozzle 0.4mm drill holes
- 4mm PTFE
For details visit https://sites.google.com/site/3dneludeltaen/3d-printer/delta-robot-nelu
Video: https://www.youtube.com/channel/UCuWyirjuE_Fe0zXUW4uCxDg/videos
