Argento Hot End
Revision as of 17:34, 17 May 2013 by Traveler (talk | contribs) (Created page with '{{Development |image = Argento_HotEnd.JPG‎ |name = Argento Hot End |description = An All Metal Hot End |status = Working |license = Pending |reprap = Arcol.hu_Hot-End_Versi…')
Argento Hot End
Release status: Working
Goals
  • Use widely available materials
  • Mix several metals with different heat transfer coefficients to slow down convection.
  • Have a long and continous path where the transformation from solid to liquid takes places, in order to minimize turbulence and get a laminar output.
  • Get rid of PFTE/Peek in favor to make it more reliable/heat proof.
  • Easy to assemble design
First version conclusions
Aluminum was used for the heat sink. A stainless steel pipe was inserted inside as heat insulation for the filament. The brass nozzle goes inserted into an aluminum non threaded heating block.
