Belts and Pulleys
Revision as of 10:04, 23 April 2013 by Robotdigg (talk | contribs) (Pulleys)
See also Choosing_Belts_and_Pulleys
Belts
Supplier From Type available Pitch Width Length Material Approximate Cost Additional notes
Charlie's 3D Technologies Belgium MXL 2,03 mm - - - 4,24 € -
RobotDigg China GT2 2 mm 6mm or 9mm 50M per roll Neoprene Rubber, Fiberglass Reinforced 1.8USD/M MOQ 50M
BBMan US Imperial/Metric
Belting Online UK many
Econobelt US many
Eke China many
Indiamart India many
KainaBelt China many
Makemendel India T2.5 2,5 mm 7 mm 700 mm - 5,49 $ -
Megadyne Italy many
Misumi multiple
Paoparts France T2.5
T5
2,5mm
5mm
5mm - PU 7,90 € / m
5,90 € / m
PolyBelt US T2.5
T5
5 mm 6 mm - polyurethane + steel 18 $ / m
3 $ / m
RepRapWorld Netherlands T2.5
T5
2,5 mm
5 mm
5 mm
5 mm
1 m neoprene
4,17 € / m -
Royal supply US GT2 2 mm 6 mm 1164 mm fiberglass / nylon / neoprene 5,48 $ -
SDP-SI US Imperial/Metric
TechPaladin US GT2 2 mm 5 mm 1160 mm neoprene 8,50 $ -
Tanals France many - - - - - don't sell to individuals
There is also some on ebay.
  • beside GT2 belts, there is also 2M that have a 2mm round pitch (like [1] and many other suppliers)
Pulleys
Supplier From Type available Pitch Tooth Size (bore, OD,...) Max belt width Material Approximate Cost Additional notes
Charlie's 3D Technologies Belgium MXL 2.03 mm 15 5.08 x 9.19 mm - Alu 4,17 € -
RobotDigg China GT2 2mm 20 5*17.5*18 mm 6mm Alu 2 $ SKYPE: robotdigg
BBMan US many
Econobelt US many
MakeMendel India T2.5 2,5 mm 16 5 mm  ? Alu 4,49 $ -
Misumi multiple
Paoparts France T2,5
T5
RepRapWorld Netherlands T5 5 mm 8 5 mm x 17 mm x 20 mm  ? Alu 4,75 € Pulley profile has play resulting in lash when reversing
Royal Supply US GT2 2 mm 18 4,7 mm 6 mm Alu cost you'll need to redrill the bore (3/16") to fit usual 5 mm motor shaft
SDP-SI US many
TechPaladin US GT2 2 mm 36 5 mm 6 mm plastic/bronze 6 $ -
Ultimachine US GT2 2 mm 20 5 mm 6 mm Alu 11 $ use two set screws
Cable
