Comparison of Electronics
Revision as of 03:28, 21 September 2017 by Dc42 (talk | contribs) (Updated Duet WiFi specs, added Duet Ethernet)
This first list of boards are the ones currently most talked about on the Reprap IRC channel ( for methodology see here ), by decreasing order of popularity.
Incidentally, they also happen to be the most often recommended on IRC.
Board License Latest
Version
Extruders Fans Heaters Endstops Temp sense Ethernet WiFi SPI I2C RS485 ISP CPU CPU Speed ( Mhz ) Stepper driver Other features
RAMPS GPL v1.4 1-2 3 (maximum, shared w/ Heaters) 3 (maximum, shared with Fans) 6 3 No No Yes, future Yes, future No (via Arduino: Yes) No (via Arduino: Yes) Arduino Mega 8 bits ATmega1280, ATmega2560 16 A4988, Pololu boards
SmoothieBoard GPL and CERN OHL v1.1 1 or 2 2+ 4+ 6 4, with possibility of more Yes As an extension 2 2 As an extension ISP, DFU(USB), JTAG 32 bit ARM ( LPC1769 ) 120 A5984 ( 1/32 microstepping ), digital current control MicroSD card, file_based config, USB composite (serial + mass storage), Network with web interface, file-based configuration
Generation 7 Electronics CC BY-NC-SA v2.0 1 1 2 3 2 No No 2 - - yes 32-bits LPC1114 48 A4988, Pololu boards Designed for DIY, mill-/etchable PCB.
RAMBo CC ShareAlike 3.0 1.1b 2 2 2 6 4 No No 1 1 0 USB Atmega2560, Atmega32u2 16 A4982, digital current control all-in-one RAMPS board, marlin FW, extra ports
see http://reprap.org/wiki/Rambo
Duet WiFi CERN OHL 1.02 2 (up to 9 with DueX5 expansion board) 3 (up to 9 with DueX5) 3 (up to 8 with DueX5) 5 (12 with Duex5) 3 (8 with Duex5) also up to 8 digital PT100/Thermocouple inputs on daughterboards No Yes 3 1 0 USB, SD card, web 32-bit ARM SAM4E8E microprocessor with hardware floating point 120 Trinamic TMC2660 stepper drivers, up to 2.8A, up to x256 microstepping, digital current control Built in web interface with high speed file upload to SD card, high speed SD card, native USB, file-based config, 18A heated bed support
Duet Ethernet CERN OHL 1.02 2 (up to 9 with DueX5 expansion board) 3 (up to 9 with DueX5) 3 (up to 8 with DueX5) 5 (12 with Duex5) 3 (8 with Duex5) also up to 8 digital PT100/Thermocouple inputs on daughterboards Yes No 3 1 0 USB, SD card, web 32-bit ARM SAM4E8E microprocessor with hardware floating point 120 Trinamic TMC2660 stepper drivers, up to 2.8A, up to x256 microstepping, digital current control Built in web interface with high speed file upload to SD card, high speed SD card, native USB, file-based config, 18A heated bed support
Megatronics GPLv2 v3.0 1-3 2 3 6 6 No No Yes Yes No Yes 8 bits ATmega2560 16 A4988, Pololu boards
Version
This second list lists other less popular boards, and boards that have only historical significance :
Version
SinapTec GPL 328.02 1  ? 1 3  ? No No  ?  ?  ? Not with Nano USB ATmega328, Arduino Nano 16 Any Standard etchable
Sanguinololu GPL v1.3a 1 3 2 3 2 No No - 1 - 1 8 bits ATmega644P (or ATMEGA1284) 16 A4988, Pololu boards
Azteeg X3 Pro  ? v1.0 5 8 (maximum, shared w/ Heaters) 8 (maximum, shared w/ Heaters) 6 6 + 2 thermocouple No No  ?  ?  ?  ? 8 bits ATmega2560 19 A4988, Pololu boards, digital current control MicroSD-Card, 24V, clickwheel, USB
Melzi GPL v2.0 1 1 2 3 2 No No 1 1 1 1 8 bits ATmega1284P 16 A4982
Minitronics GPLv2 v1.1 1-2 1 2 3 3 No No Yes Yes No Yes 8 bits ATmega1281 16 DRV8825
Printrboard CC ShareAlike 3.0 v0.7 1 1 2 4 2 No No 1 1  ? USB 8 bits AT90USB1286 16 A4982
Teensylu GPL v0.7 1 1 2 4 2 No No 1 1  ? USB 8 bits AT90USB1286 20 Pololu boards
Ultimaker Electronics GPL v1.5.4 1-2 3 3 6 3 No No - - - - Arduino Mega 8 bits ATmega1280 16 A4988, Pololu boards
Generation 6 Electronics GPL v1.0 1 0 2 3 2 No No 1 1 1 1 8 bits ATmega644P 16 DRV8811
4pi from Kliment[1][2] GPL beta 1-2 2 3 6 4 No No 1 1  ?  ? 32 bit ARM ( SAM3U ) 96 A4982
Azteeg X1 CC ShareAlike 3.0 v1.5 1 1 2 3 2 No No 1 1 - 1 ATmega1284P(644P on v1.0) 16 A4988, Pololu boards
Azteeg X3 CC ShareAlike 3.0 v1.2 2 4 3 6 3 No No 1 1 - 1 ATmega1280/2560 16 A4988, Pololu boards
R2C2 electronics CC Non Commercial v1.2 1 1 2 3 2 No No 2 1  ? USB 32 bits ARM ( LPC175x ) 100 A4988
Pololu Electronics GPL  ?  ?  ?  ?  ?  ? No No  ?  ?  ?  ? Arduino Mega 8 bits ATmega1280 16 A4988, Pololu boards
Generation 3 Electronics/Tech Zone Remix‎ GPL  ?  ?  ?  ?  ?  ? No No  ?  ?  ?  ? 8 bits ATMEGA644P 16 A3982
Monotronics GPL  ?  ?  ?  ?  ?  ? No No  ?  ?  ?  ? 8 bits Atmega644P 16  ?
Phoenix CERN Open hardware license  ? 3 2  ?  ? No No  ?  ?  ?  ?  ? 8 bits Atmega644P 16 TB6560
Brainwave GPL 1.0 1 1 1 3 2 No No - - -  ? 8 bits AT90USB646 16 LV8713T
RUMBA GPL 1.0 3 2 3 6 4 No No  ? 1 0 USB & ISP Headers for both microcontroller 8 bits Atmega2560, Atmega16u2 16 A4988, DRV8825 Pololu boards all-in-one RAMPS board, marlin FW, sprinter, repetier, JTAG Breakout
Duet CERN OHL 0.6 1 (5 with Duex4) 1 (up to 5 with Duex4) 2 (up to 6 with Duex4) 4 (8 with Duex4) 2 (6 with Duex4) Yes No 1 2 0 USB, wreb 32-bit ARM SAM3X8E microprocessor, same as Arduino Due. 84MHz A4982, digital current control µSD card ,native Ethernet, native USB, file based config, built in web interface
Duet CERN OHL 0.8.5 2 (6 with Duex4) 2 (up to 6 with Duex4) 3 (up to 7 with Duex4) 4 (8 with Duex4) 3 (7 with Duex4) Yes No 1 2 0 USB, web 32-bit ARM SAM3X8E microprocessor, same as Arduino Due. 84MHz A4982, digital current control µSD card native Ethernet, native USB, file-based config, built in web interface
RADDS CC BY-NC-SA 3.0 1.5 3-5 6 (maximum, shared w/ Heaters) 6 (maximum, shared w/ Fans) 6 5 + 1 Thermocouple No No yes yes RS232 No (via
Arduino: Yes)
32-bit ARM SAM3X8E Arduino DUE 84MHz RAPS128 (THB6128-based), ((A4988?), (DRV8825?) Pololu boards) USB, SD card, Repetier-Firmware, Marlin4Due, RepRap-Firmware With RADDS Extension Board 8 StepperMotors + Bluetooth or W-Lan etc...
SAV_MKI CC BY-SA Rev.C 1 3 2 4 2 No No 1 1  ? 1 8 bits AT90USB1286 16 Pololu boards uSD, A4988, DRV8825 pololu boards, native USB, BT interface (though dongle), Marlin, LCD companion board SAV 3D LCD
Replicape CC BY-SA Rev A4A 2 3 2 6 3 Yes No 1 1 0 1 32 bit ARM Cortex-A8 1000 DRV8825 uSD, 4GB flash (on BBB), USB host, PRU: 200 MHz co processor, LCD companion board Manga Screen
Version
Further reading
