Easyflowhotend
Revision as of 05:07, 5 October 2012 by Jamesdanielv (talk | contribs) (Created page with 'This is a hot end style i am using for my bowden designed printer, but it should work for any hot end. it allows easy flow of material through a simple staged melting process tha…')
This is a hot end style i am using for my bowden designed printer, but it should work for any hot end. it allows easy flow of material through a simple staged melting process that allows heat to effectively propagate though the feedstock changing viscosity of liquid and reducing internal pressure. not much else is understood other than it takes less force to extrude 3mm feedstock.
here is a picture
