Echorap
Revision as of 13:47, 15 November 2012 by Stephaner (talk | contribs)
EchoRap
Low cost, robust RepRap
CCSANC
RepStrap, RepRap
None
The EchoRap is a simple and robust RepRap designed by Robotic Sequencing in Montreal’s first and only Fab Lab, ÉchoFab. It’s a low cost and simplified version of the original RepRap using tubes instead of threaded rods for a different geometry. The design is licensed under Creative Commons Non-Commercial</a>, so if you have acces to a 3D printer, you can print one for yourself or to give to a friend. Files to print parts are available on Thingiverse.
The design allows builders to build it as a RepRap or a RepStrap. All parts can be printed or cut. Assembly of the structure is very easy: tubes and simple coupling. The X Y Z axes can be enlarged using longer tubes and rods. Current table size allows the use of standard Mendel or Prusa heated beds. Gen7 Electronics, PrintrBoard rev D has been tested and works well. Other RepRap electronics can also be used. All the sofware is Open-Source.
SPECIFICATIONS
Overall Dimensions: 510mm x 585mm x 540mm (20.1in x 23.1in x 21.26in)
Weight: 8.18kg (18lbs)
Usable Print Area: 220mm x 220mm x 200mm (7.9in x 7.9in x 7.87in)
VIDEOS The EchoRap is action, see it printing it's own parts: [2]
BILL OF MATERIAL
Items / Quantity
Structure
Y axis Tube 1.125" 14" / 2
X axis Tube 1.125" 15" / 2
Z axis Tube 1.125" 15" / 2
Top Tube Handle Bar 1.125" 23" / 1
Tube Joint / 18
EchoRap Specific Parts
P1Y NEMA 17 Mount / 1
P2Y Bearing Holder / 1
P3Z NEMA 17 Mount / 4 (Updated from 2 to 4 on Rev1)
P4Z Top Mount / 0 (Replaced by 2 P3Z)
P5X NEMA 17 Mount / 1
P6X Right Mount / 1
P7 Extruder Mount / 1
P8 Table / 1
P9 LM12UU Holder / 8
P10 Adaptor 1.125" to 12mmx0.5" long / 12
Moving Parts
12 mm Rod 13" / 4
LM12UU Linear Bearing 12x21x30mm / 8
608ZZ Bearing (to build structure, extruder not counted) / 2
5/16 18TPI Threaded Rod 13" / 2
Pulley GT2 36 teeth, 6mm width / 2
Belt GT2 497 teeth, 6mm width / 2
Hardware
M3 X 12mm Socket Bolt (motor mount) / 20
M3 X 25mm Socket Bolt (P1, P2, P3, P4 attach) / 6
M3 Hex Nut / 6
Multipurpose Miniature Tie 102mm / 100
5/16 Nut / 4
M8 X 30mm Bolt / 2
M8 Lock Nut / 2
M8 Washer / 4
M8 Large Washer / 4
L-Shaped Metal Mount 50mmx50mmx12mm / 2
Electronics
NEMA 17 Stepper Motor 62 oz-in / 5
PrintrBoard rev D / 1
Extruder Wade / 1
Hotend J-Head / 1
PCB Heated Bed MK1 or more / 1
ATX Power Supply / 1
Motors Cables / 5
Other Cables / 7
DOCUMENTATION AND SOFTWARE
Files to make one on Thingiverse
Ordering one
échoRap Wiki(in french)
Firmware for PrintrBoard Rev D</a> on GitHub.
Firmware for RepRap Gen7 Electronic v1.3.1 on GitHub.
