Revision as of 01:06, 15 September 2012 by BouncyMonkey (talk | contribs) (A new guide to the Z-Axis developments. This image is to help identify the relevant STL for users.)
Size of this preview: 600 × 600 pixels. Other resolutions: 240 × 240 pixels | 800 × 800 pixels.
Original file (800 × 800 pixels, file size: 143 KB, MIME type: image/jpeg)
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 20:59, 27 October 2012 | 800 × 800 (143 KB) | BouncyMonkey (talk | contribs) | Quite a few changes to reflect development suggestions from Vik. Of note, are; The switch holder has been moved to keep the adjustment screw clear of the x-axis belts, the top brackets for the z-axis have been reshaped to give better stiffness to the z-a | |
18:35, 26 September 2012 | 800 × 784 (137 KB) | BouncyMonkey (talk | contribs) | Yeah OK, I just uploaded the wrong one. Try this instead | ||
18:33, 26 September 2012 | 800 × 784 (137 KB) | BouncyMonkey (talk | contribs) | Images changed to reflect the increased clearance between the z-axis drive support and the big gear and changes to the z-axis support base idler end so that the holes match the driven end. | ||
20:37, 23 September 2012 | 800 × 784 (130 KB) | BouncyMonkey (talk | contribs) | Z-Axis Assembly showing redesigned arrangement for the boot end drives. This arrangement should stop the binding that was occurring in the original arrangement. | ||
01:06, 15 September 2012 | 800 × 681 (211 KB) | BouncyMonkey (talk | contribs) | A new guide to the Z-Axis developments. This image is to help identify the relevant STL for users. |
- You cannot overwrite this file.
File usage
The following 2 pages link to this file:
