Revision as of 20:59, 27 October 2012 by BouncyMonkey (talk | contribs) (uploaded a new version of "File:AssemblyGuideV3sml.jpg": Quite a few changes to reflect development suggestions from Vik. Of note, are; The switch holder has been moved to keep the adjustment screw clear of the x-axis belts, the top brackets for )
Original file(800 × 800 pixels, file size: 143 KB, MIME type: image/jpeg)
A new guide to the Z-Axis developments. This image is to help identify the relevant STL for users.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current20:59, 27 October 2012Thumbnail for version as of 20:59, 27 October 2012800 × 800 (143 KB)BouncyMonkey (talk | contribs)Quite a few changes to reflect development suggestions from Vik. Of note, are; The switch holder has been moved to keep the adjustment screw clear of the x-axis belts, the top brackets for the z-axis have been reshaped to give better stiffness to the z-a
18:35, 26 September 2012Thumbnail for version as of 18:35, 26 September 2012800 × 784 (137 KB)BouncyMonkey (talk | contribs)Yeah OK, I just uploaded the wrong one. Try this instead
18:33, 26 September 2012Thumbnail for version as of 18:33, 26 September 2012800 × 784 (137 KB)BouncyMonkey (talk | contribs)Images changed to reflect the increased clearance between the z-axis drive support and the big gear and changes to the z-axis support base idler end so that the holes match the driven end.
20:37, 23 September 2012Thumbnail for version as of 20:37, 23 September 2012800 × 784 (130 KB)BouncyMonkey (talk | contribs)Z-Axis Assembly showing redesigned arrangement for the boot end drives. This arrangement should stop the binding that was occurring in the original arrangement.
01:06, 15 September 2012Thumbnail for version as of 01:06, 15 September 2012800 × 681 (211 KB)BouncyMonkey (talk | contribs)A new guide to the Z-Axis developments. This image is to help identify the relevant STL for users.
  • You cannot overwrite this file.
The following 2 pages link to this file:
