File:CompliantMechanismSheetmetal.zip
Revision as of 10:57, 20 January 2015 by Hari Seldon (talk | contribs)
CompliantMechanismSheetmetal.zip (file size: 11 KB, MIME type: application/zip)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
Compliant mechanism 2D sheet metal pattern in svg, pdf, and dxf formats (all generated with InkScape)
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 01:17, 31 May 2010 | (11 KB) | MattMoses (talk | contribs) | Compliant mechanism 2D sheet metal pattern in svg, pdf, and dxf formats (all generated with InkScape) |
- You cannot overwrite this file.
File usage
The following page links to this file:
