File:Corner plate.jpg
Size of this preview: 337 × 599 pixels. Other resolutions: 135 × 240 pixels | 1,152 × 2,048 pixels.
Original file (1,152 × 2,048 pixels, file size: 247 KB, MIME type: image/jpeg)
This corner plate is sold to help build square-section steel shelving. It just happens to be a perfect fit for 20mm square V-slot. There is even a little hole for the tension cable end!
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 01:49, 24 May 2016 | 1,152 × 2,048 (247 KB) | Aegidius (talk | contribs) | This corner plate is sold to help build square-section steel shelving. It just happens to be a perfect fit for 20mm square V-slot. There is even a little hole for the tension cable end! |
- You cannot overwrite this file.
File usage
The following page links to this file:
