File:Ironing the layout.JPG
Revision as of 07:12, 30 June 2013 by RobertKuhlmann (talk | contribs) (The layout is printed on a catalog page. The paper should be very smooth with no visible or tactile structure and it should be waxed. The iron (on highest temperature possible; for linnen) melts the toner, that then gets in close contact to the copper. )
Size of this preview: 800 × 533 pixels. Other resolutions: 320 × 213 pixels | 3,888 × 2,592 pixels.
Original file (3,888 × 2,592 pixels, file size: 3.26 MB, MIME type: image/jpeg)
Do not iron the paper directly. Always use one or two layers of paper towels between the iron and the layout, because you might smear fine details of the print otherwise.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 07:12, 30 June 2013 | 3,888 × 2,592 (3.26 MB) | RobertKuhlmann (talk | contribs) | The layout is printed on a catalog page. The paper should be very smooth with no visible or tactile structure and it should be waxed. The iron (on highest temperature possible; for linnen) melts the toner, that then gets in close contact to the copper. |
- You cannot overwrite this file.
File usage
The following 2 pages link to this file:
