File:LapRap Plano corte.zip
Revision as of 15:08, 14 September 2015 by Hanlest (talk | contribs) (Plano de corte en aluminio de 3mm)
LapRap_Plano_corte.zip(file size: 17.12 MB, MIME type: application/zip)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current22:49, 16 February 2016 (17.12 MB)Hanlest (talk | contribs)Se agrega un soporte para el ventilador del hotend en la version simple y doble se modifica el tensor para la correa del eje Y se agregan orificios para los dos extrusores bowden en el marco de la impresora se agregan orificios para los cables de la pa...
09:03, 8 October 2015 (9.25 MB)Hanlest (talk | contribs)
13:52, 6 October 2015 (13.44 MB)Hanlest (talk | contribs)Se modifican alguna piezas que tenían errores de dibujo
23:28, 4 October 2015 (12.33 MB)Hanlest (talk | contribs)Se realizan pequeñas modificaciones luego del armado del prototipo
11:46, 15 September 2015 (11.73 MB)Hanlest (talk | contribs)Se repararon algunos problemas de alineación en el modelo
15:08, 14 September 2015 (9.16 MB)Hanlest (talk | contribs)Plano de corte en aluminio de 3mm
  • You cannot overwrite this file.
The following 2 pages link to this file:
