File:Minimug.stl
Revision as of 09:14, 2 July 2008 by Sebastien Bailard (talk | contribs) (This is a small (20mm tall) mug with gently tapering sides. Printed on a RepRap, it should be sufficiently watertight and alcoholtight to raise a toast to your complete machine with.)
Minimug.stl(file size: 49 KB, MIME type: unknown/unknown)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current09:14, 2 July 2008 (49 KB)Sebastien Bailard (talk | contribs)This is a small (20mm tall) mug with gently tapering sides. Printed on a RepRap, it should be sufficiently watertight and alcoholtight to raise a toast to your complete machine with.
  • You cannot overwrite this file.
The following page links to this file:
