File:RAMPS1.4 TestCode.pde
Revision as of 07:09, 2 October 2011 by Misan (talk | contribs) (Arduino test code: It switches on and off all the MOSFET outputs (this will make the leds blink) just be careful not to have the heated bed and extruder heater connected unless you want to heat them. Plus it will move back and forth all the stepper motors)
RAMPS1.4_TestCode.pde(file size: 3 KB, MIME type: text/x-c++)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
Arduino test code: It switches on and off all the MOSFET outputs (this will make the leds blink) just be careful not to have the heated bed and extruder heater connected unless you want to heat them. Plus it will move back and forth all the stepper motors connected.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current07:09, 2 October 2011 (3 KB)Misan (talk | contribs)Arduino test code: It switches on and off all the MOSFET outputs (this will make the leds blink) just be careful not to have the heated bed and extruder heater connected unless you want to heat them. Plus it will move back and forth all the stepper motors
  • You cannot overwrite this file.
The following file is a duplicate of this file (more details):
There are no pages that link to this file.
