File:Rroofl Z-axis Assembly-Blender257.zip
Revision as of 21:01, 27 October 2012 by BouncyMonkey (talk | contribs) (uploaded a new version of "File:Rroofl Z-axis Assembly-Blender257.zip": Modifications to the top bracket and the bottom bracket of the z-axis to reflect adjustments in switch locations, and greater stiffness for the z-axis assembly.)
Rroofl_Z-axis_Assembly-Blender257.zip (file size: 1.29 MB, MIME type: application/zip)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
This is a single Blender file containing all of the development models for the Rroofle Z-axis. It also includes other components so that it can all be made to line up properly. If we're lucky it may even be able to be made.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 21:01, 27 October 2012 | (1.29 MB) | BouncyMonkey (talk | contribs) | Modifications to the top bracket and the bottom bracket of the z-axis to reflect adjustments in switch locations, and greater stiffness for the z-axis assembly. |
18:39, 26 September 2012 | (1.35 MB) | BouncyMonkey (talk | contribs) | The z-axis base ends have been modified to have the same bolt hole pattern and spacing and the clearance between the z-axis frame and the big gear has been enlarged. | |
20:39, 23 September 2012 | (1.44 MB) | BouncyMonkey (talk | contribs) | This edition has major changes to the z-axis drive base to sort out binding issues. Also most holes are slightly larger to allow easier fitting and less work with a drill. | |
00:50, 15 September 2012 | (972 KB) | BouncyMonkey (talk | contribs) | This is a single Blender file containing all of the development models for the Rroofle Z-axis. It also includes other components so that it can all be made to line up properly. If we're lucky it may even be able to be made. |
- You cannot overwrite this file.
File usage
The following 2 pages link to this file:
