File:Smooth rod collar.jpg
Revision as of 12:03, 26 August 2011 by Lanthan (talk | contribs) (== Smooth rod failsfe collar/clamp from an M8 nut == * you'll need a stationary drill (drill press), a center punch, 8mm and 2.5 mm drills, an M3 tap, M8 nuts, m3x6 (or similar) bolts * drill out the nut's center and apply 5-20 circular file strokes unt)
Size of this preview: 800 × 541 pixels. Other resolutions: 320 × 217 pixels | 1,030 × 697 pixels.
Original file (1,030 × 697 pixels, file size: 162 KB, MIME type: image/jpeg)
- you'll need a stationary drill (drill press), a center punch, 8mm and 2.5 mm drills, an M3 tap, M8 nuts, m3x6 (or similar) bolts
- drill out the nut's center and apply 5-20 circular file strokes until the nut fits snugly the 8 mm smooth rod
- punch the center of two nut's sides 120 dregrees apart
- change to the 2.5 mm drill and drill the nut's sides
- Tap those holes to M3
- File the metal scrapes and adjust the collars on the axes. Tighten ad lib.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 12:03, 26 August 2011 | 1,030 × 697 (162 KB) | Lanthan (talk | contribs) | == Smooth rod failsfe collar/clamp from an M8 nut == * you'll need a stationary drill (drill press), a center punch, 8mm and 2.5 mm drills, an M3 tap, M8 nuts, m3x6 (or similar) bolts * drill out the nut's center and apply 5-20 circular file strokes unt |
- You cannot overwrite this file.
File usage
The following page links to this file:
