File:Washer separated from gear.png
Revision as of 08:29, 22 May 2011 by DeuxVis (talk | contribs) (After 10 minutes of solvent and knife actions, taddaa ! Nearly clean separation of the 2 pieces forming the big lasercut gear of my Techzone Huxley extruder. Although a bit of sanding might be enough, to be sure to work on plane surfaces, I'll do the plac)
Original file(1,024 × 767 pixels, file size: 694 KB, MIME type: image/png)
After 10 minutes of solvent and knife actions, taddaa ! Nearly clean separation of the 2 pieces forming the big lasercut gear of my Techzone Huxley extruder. Although a bit of sanding might be enough, to be sure to work on plane surfaces, I'll do the placement on the other side of each piece.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current08:29, 22 May 2011Thumbnail for version as of 08:29, 22 May 20111,024 × 767 (694 KB)DeuxVis (talk | contribs)After 10 minutes of solvent and knife actions, taddaa ! Nearly clean separation of the 2 pieces forming the big lasercut gear of my Techzone Huxley extruder. Although a bit of sanding might be enough, to be sure to work on plane surfaces, I'll do the plac
  • You cannot overwrite this file.
The following page links to this file:
Metadata
