Revision as of 01:49, 11 April 2010 by MattMoses (talk | contribs) (Closeup of case at beginning of test. The wax inside is molten so the interior is visible. Near the top of the case interior, note the slanted cut in the drain tube, where the thinner vent tube passes out and outside. Molten wax exits from the slanted )
Size of this preview: 800 × 600 pixels. Other resolutions: 320 × 240 pixels | 1,024 × 768 pixels.
Original file (1,024 × 768 pixels, file size: 138 KB, MIME type: image/jpeg)
Closeup of case at beginning of test. The wax inside is molten so the interior is visible. Near the top of the case interior, note the slanted cut in the drain tube, where the thinner vent tube passes out and outside. Molten wax exits from the slanted cut, and runs down the heater into the pool at the bottom of the case. The fitting to the vacuum pump is barely visible in the top left corner of the case.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 01:49, 11 April 2010 | 1,024 × 768 (138 KB) | MattMoses (talk | contribs) | Closeup of case at beginning of test. The wax inside is molten so the interior is visible. Near the top of the case interior, note the slanted cut in the drain tube, where the thinner vent tube passes out and outside. Molten wax exits from the slanted |
- You cannot overwrite this file.
File usage
The following page links to this file:
