Firmware/Linear Acceleration
Linear acceleration (as opposed to Constant_Acceleration) is possible using slightly more complicated math to calculate the stepper positions. But as the precise answer can be attained only analytically, there are small errors which accumulate greatly over time when estimations are used.
Another way to achieve linear acceleration is to bend time to our will. Rather than calculating the precise time of the next step during each timer interrupt, we can scale real time and perform the analytical calculus needed to determine how much scaled time has passed during the current move. If we do this often enough (Teacup Firmware uses a 2ms "background" timer for such tasks) we can adjust our velocity in near-real time to match a planned velocity path.
The velocity path can be calculated on the fly as the integration of some linear acceleration value, or it can simply be a linear velocity ramp, the integral of some constant acceleration value. But it can also be a linear approximation to some complex curve.
I am using it to approximate the velocity curve discussed in this paper (PDF) on exponential velocity planning.
