Firmware Capabilities Protocol
Revision as of 05:40, 27 November 2019 by Repetier (talk | contribs) (Added DOOR capability.)
Idea
While it is nice if a firmware supports some special features, it would be even better if hosts would detect that these are available so they start using them. Especially with the wild growth of firmware forks and versions, no host can know which variant can handle what. So at least for Repetier-Firmware we introduce with version 1.0 a new simple protocol to tell hosts what features are available, so they can activate them.
Protocol definition
To make it easy to detect, a standard M115 report gets now extended by one or more lines, each line telling what capability. These lines have the following format:
Cap:<NameOfCapability>:<0 or 1>
Notice: no spaces allowed, Name is upper case with underline to separate words. Lines MUST start with "Cap:" so it can be parsed very quickly by hosts.
The last value indicates if that capability is supported or not. The simple absence of a message is not enough since it would be possible, that the firmware simply does not report capabilities at all and host has to make assumptions like showing EEPROM editor even with the risk that it is not available. Whereas a 0 value shows that a function is known, but the functionality is not implemented/active.
Knowing different developers will add other capabilities is no real problem as long as all names differ, so hosts can distinguish them by name. Hosts not understanding a name simply ignore them.
Currently-defined capabilities
Cap:AUTOLEVEL
The firmware supports auto-leveling with G29.
Cap:AUTOREPORT_TEMP
The firmware can automatically report temperatures. This feature must be enabled by M155 S[interval] so older hosts won't get redundant reports from M105 and this feature.
Cap:AUTOREPORT_SD_STATUS
The firmware will auto-report the SD Card status, using M27 S to enable and set the interval.
Cap:BUILD_PERCENT
The firmware supports setting the progress percentage with M73 P, required to show progress for host-based printing on the machine's display.
Cap:CASE_LIGHT_BRIGHTNESS
The firmware supports setting the case light brightness with M355 S and values 2-255.
Cap:CHAMBER_TEMP[ERATURE]
The firmware has support for a Chamber thermal sensor.
Cap:EMERGENCY_PARSER
The firmware supports immediate execution of commands M108, M112, and M410. With this capability M108 can be used to break out of M0/M1, M109, and M190.
Cap:EEPROM
The firmware is compiled with EEPROM support.
Cap:HOST_RESCUE
Promotes availability of M415 to help hosts to recover from an interrupted connection or power loss. See the M415 description on the G-codes page more details about the implementation.
Cap:LEVELING_DATA
The firmware supports M420 V to report the stored leveling (mesh or matrix) data.
Cap:MOTION_MODES
The firmware supports motion modes for G0, G1, G2, G3, G5, and G38, and adds the G80 command to cancel the current motion mode. With motion modes the firmware only needs the parameters for subsequent moves following one of these common motion commands.
Cap:PAREN_COMMENTS
The firmware allows parentheses comments within G-code lines.
Cap:PRINT_JOB
The firmware supports the Print Job Timer commands M75 Start, M76 Pause, and M77 Stop.
Cap:PROGRESS
The firmware supports the progress protocol:
  • M530 S<printing> L<layer> - Enables explicit printing mode (S1) or disables it (S0). L can set layer count.
  • M531 filename - Set the filename being printed.
  • M532 X<percent> L<curLayer> - Update current print state progress (X=0..100) and layer L.
This allows a host to enable a special information mode on LCD display, so users see progress in percent, model being printed, layer being printed, and total layer count. (Hosts can also use M117 to show time remaining on the LCD status line.)
This feature should only be enabled if a display is available to show it, otherwise the extra commands are useless.
Cap:SERIAL_XON_XOFF
The firmware supports serial XON/XOFF handshaking.
Cap:SOFTWARE_POWER
The firmware supports enabling/disabling power with M80 and M81.
Cap:THERMAL_PROTECTION
The firmware has thermal protection enabled. Hosts can use this item to warn users of a potential fire hazard.
Cap:TOGGLE_LIGHTS
The firmware supports turning the case lights on/off with M355 S1 and M355 S0. (May also support setting case light brightness with S values 2-255.)
Cap:VOLUMETRIC
The firmware supports Volumetric Extrusion with M200 T D.
Cap:Z_PROBE
The firmware supports single point Z probing with G30.
Cap:DOOR
The firmware sends signals to allow hosts to warn about an open door. The messages are
DoorOpened
DoorClosed
Optional prefixed with echo:
