Frax3d
Revision as of 06:35, 26 April 2016 by Bcndynamics (talk | contribs) (adding links)
Frax 3D Documentation
Frax 3D
3D Printer, metallic structure, Core XY
Frax 3D
Frax3D is a 3D printer that has a CoreXY system that allows us to work faster due to its low inertia. Its structure is completely of stainless steel sheet metal, giving a professional finish, greater structural rigidity and compact design. This 3D printer can operate with a print speed of 80mm/s.
This is a completely OpenSource 3D printer and therefore all components used follow this philosophy and are fully interchangeable by any other similar component (not limited to our processors, filaments, extruder, etc.). Also, in the design, they are included all necessary geometries so that this project can be expanded or modified (for example different extruders and fittings extra holes to attach any gadget that you consider appropriate).
Characteristics of the new Frax3D:
  • CoreXY System for lower inertia and higher print speeds and acceleration
  • Wide range of available materials thanks to their Full metal extruder E3D
  • Different possibilities of extrusion (direct or bowden) with one or two extruders
  • High definition printing (HD) with a calibrated spindle and special nut on the Z axis. Layers of 0.1mm or less
  • Heated bed (MK2b 200x200mm) to print ABS, PLA, HIPS, Flexible, nylon …
  • Autonomous 3D printing thanks to LCD screen and button and SD card reader. No need to be connected to a PC
  • Easy operation
  • Simple, compact and elegant design
  • OpenSource technology
  • Easy to assemble.
La impreosora 3D Frax3D es una impresora con sistema CoreXY que nos permite imprimir más rápido gracias a su reducida inercia. Su estructura es completamente en chapa metálica de acero inoxidable, dándole un acabado más profesional, mayor rigidez estructural y un diseño compacto. Esta impresora puede imprimir a una velocidad de 80mm/s. Esta es una impresora totalmente OpenSource y por lo tanto todos los componentes utilizados siguen esta filosofía y son plenamente intercambiables por cualquier otro componente de características similares (no está limitada a nuestros procesadores, filamentos, extrusor, etc.). Además en el diseño se han incluido las geometrías necesarias para que este proyecto pueda ser ampliable o modificable (por ejemplo diferentes acoples de extrusores y agujeros extras para poder sujetar cualquier gadget que consideréis apropiado).
Características de la Frax3D:
  • Altas velocidades de impresión
  • Gran rango de materiales disponibles gracias a su extrusor E3D Full metal
  • Diferentes posibilidades de extrusión (directo o bowden) con uno o dos extrusores
  • Impresión en alta definición (HD) con un husillo calibrado y tuerca especial en el eje Z. Capas de 0.1mm o incluso menores
  • Sistema CoreXY para menor inercia y mayor aceleración y velocidades de impresión
  • Cama caliente (MK2b 200x200mm) para imprimir ABS, PLA, HIPS, Flexible, nylon…
  • Impresión autónoma incluyendo pantalla LCD con botón y lector de tarjetas SD
  • Fácil manejo
  • Diseño sencillo, compacto y elegante
  • Tecnología OpenSource
Interesting Links
