FuseBox
FuseBox
Description | An affordable aluminum-framed CoreXY printer.
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
FuseBox is a cheap CoreXY 3D printer that uses an aluminum extrusion frame.
Goal
To design an affordable, RepRappable 3D printer using CoreXY kinematics that offers high speed and quality.
Features
- Aluminum structure based on Misumi 1515 extrusions and printed brackets
- Uses a stacked variant of CoreXY that eliminates belt crossing
- Total materials cost under $350
- 210x160x200mm build area
- Capable of 0.5mm layer height and 100 mm/s printing
- Mostly RepRappable parts and easily hackable/upgradeable
- Provision for direct and Bowden extruder setups (Bowden currently preferred due to frame rigidity issues)
- Low moving mass—all motors stationary except extruder motor in direct-drive version
- Portable—all hardware and electronics (except for filament spool) are integrated within the frame
- No specialized tools or equipment necessary for assembly
Bill of Materials
Printed Parts
A zip file containing all the printed parts can be found here: File:FuseBox Printed Parts.zip
Other Parts
Item | Quantity | Note | |
1515 Extrusion 380mm | 4 | ||
1515 Extrusion 330mm | 2 | ||
1515 Extrusion 345mm | 4 | ||
1515 Extrusion 240mm | 2 | ||
M3x6mm Bolt | 96 | ||
M3x10mm Bolt | 10 | ||
M3 Nut | 100 | ||
M5x25mm Bolt | 6 | ||
M5 Locknut | 6 | ||
625 Bearing | 9 | ||
250mm M8 Threaded Rod | 1 | ||
300mm M8 Smooth Rod | 6 | ||
LM8UU Linear Bearing | 4 | ||
LM8LUU Linear Bearing | 4 | ||
5mm to 8mm Flex Coupler | 1 | Clamping type preferred to reduce wobble | |
2mm Pitch GT2 Belt 3m | 1 | ||
20 Tooth GT2 Pulley | 2 | ||
Bed Leveling Springs | 4 | ||
RAMPS 1.4 | 1 | ||
Arduino Mega | 1 | ||
NEMA-17 Stepper Motors | 4 | Tested with 76 oz-in steppers | |
12V LED Power Supply | 1 | Tested with a 30A supply | |
40mm 12V Fan | 2 | ||
MK8 Drive Gear | 1 | ||
J-Head-compatible Hotend | 1 | Tested with Aluhotend V6; E3D support coming soon | |
8"x10"x 0.125" Glass Sheet | 1 |
Development
Version 1.0
Initial variant. Uses a non-intersecting CoreXY design to eliminate belt crossing issues.
Issues
- Z-axis issues—slight wobble and linear bearing binding
- Slight rigidity issues caused by weak corner joints
- Extruder grip issues leading to inconsistent extrusion
- Untidy wiring
Todo
- Endstop integration (possibly with inductive z-probe)
- Cooling fan addition to improve bridging and top speed for small parts
- Bowden option for lower moving mass (will retain direct extruder for flexible materials)
- Diagonal aluminum braces on sides
- Reduce clearances for additional build area
Version 1.1
Changes'
- New compact extruder design with more solid hot end mount and fan duct addition
- Bowden extruder carriage designed; cold end still in development
- 608 bearing idler replaced by a 625 idler
- XY-gantry made more compact, resulting in ~18mm increase in maximum z-axis height
- Z axis changes: bar spacing reduced, additional reinforcement for z-nut crosspiece
Issues
- Slight z-wobble
- Rigidity
- 625 Idler breakage problem
Todo
- Additional bracing
- Endstop inregration
1.1B Uses a bowden extruder and replaces Aluhotend V6 with an E3D-Lite6. New idler design improves strength and extrusion consistency.
Video
<videoflash>I3xibPxbO2s</videoflash>
