G-code
Revision as of 16:32, 27 November 2011 by Geeksbase (talk | contribs) (added g-codes for a part cooler after printing, so a part will fall easier off the conveyor belt)
Introduction
This page describes the G Codes that the RepRap firmware uses and how they work.
The list of what can be done is extensible. But check this page first, and add your extension here first before you implement it.
A typical piece of GCode as sent to a RepRap machine might look like this:
N3 T0*57
N4 G92 E0*67
N5 G28*22
N6 G1 F1500.0*82
N7 G1 X2.0 Y2.0 F3000.0*85
N8 G1 X3.0 Y3.0*33
TO find out which specific gcode/s are implemented in any given firmware, please see the Firmware_features page.
(For the technically minded, the end of line is marked by both a <nl> and a <cr>. If you want to manually enter GCodes in your reprap using the Arduino Serial interface, make sure to select "Both NL & CR" on the bottom of the screen.)
This isn't accurate, firmware accepts single <nl> as well as single <cr>, or combinations thereof. Hosts should accepts all four combinations as well. --Traumflug 09:34, 20 April 2011 (UTC)
RepRap G Code Fields
This section explains the letter-preceded fields. The numbers in the fields are represented by nnn. Numbers can be integers, or can contain a decimal point, depending on context. For example an X coordinate can be integer (X175) or fractional (X17.62), whereas trying to select extruder number 2.76 would make no sense.
Letter Meaning
Tnnn Select tool nnn. In RepRap, tools are extruders
Snnn Command parameter, such as the voltage to send to a motor
Pnnn Command parameter, such as a time in milliseconds
Xnnn An X coordinate, usually to move to
Ynnn A Y coordinate, usually to move to
Znnn A Z coordinate, usually to move to
Innn Parameter - not currently used
Jnnn Parameter - not currently used
Rnnn Parameter - not currently used
Ennn Length of extrudate in mm. This is exactly like X, Y and Z, but for the length of filament to extrude. It is common for newer stepper based systems to interpret ... Better: Skeinforge 40 and up interprets this as the absolute length of input filament to consume, rather than the length of the extruded output.
Comments
G Code comments:
N3 T0*57 ;This is a comment
N4 G92 E0*67
; So is this
N5 G28*22
Will be ignored by RepRap, as will blank lines. But it's better to strip these out in the host computer before the lines are sent. This saves bandwidth.
Individual commands
Checking
N and *
These are the line number and the checksum. The RepRap firmware checks the checksum against a locally-computed value and, if they differ, requests a repeat transmission of the line of the given number.
int cs = 0;
   cs = cs ^ cmd[i];
Buffered G Commands
The RepRap firmware stores these commands in a ring buffer internally for execution. This means that there is no (appreciable) delay while a command is acknowledged and the next transmitted. In turn, this means that sequences of line segments can be plotted without a dwell between one and the next. As soon as one of these buffered commands is received it is acknowledged and stored locally. If the local buffer is full, then the acknowledgment is delayed until space for storage in the buffer is available. This is how flow control is achieved.
G0: Rapid move
Example: G0 X12
In this case move rapidly to X = 12 mm. In fact, the RepRap firmware uses exactly the same code for rapid as it uses for controlled moves (see G1 below), as - for the RepRap machine - this is just as efficient as not doing so. (The distinction comes from some old machine tools that used to move faster if the axes were not driven in a straight line. For them G0 allowed any movement in space to get to the destination as fast as possible.)
G1: Controlled move
Example: G1 X90.6 Y13.8 E22.4
Go in a straight line from the current (X, Y) point to the point (90.6, 13.8), extruding material as the move happens from the current extruded length to a length of 22.4 mm.
RepRap does subtle things with feedrates. Thus:
G1 F1500
Will set a feedrate of 1500 mm/minute, then do the move described above at that feedrate. But
G1 F1500
G1 X90.6 Y13.8 E22.4 F3000
Will set a feedrate of 1500 mm/minute, then do the move described above accelerating to a feedrate of 3000 mm/minute as it does so. The extrusion will accelerate along with the X, Y movement so everything stays synchronized.
RepRap thus treats feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over accelerations and decelerations in a way that ensures that everything moves together and the right volume of material is extruded at all points.
The first example shows how to get a constant-speed movement. The second how to accelerate or decelerate. Thus
G1 F1500
G1 X80 Y20 E36 F1500
Will do the first movement accelerating as before, and the second decelerating from 3000 mm/minute back to 1500 mm/minute.
To reverse the extruder by a given amount (for example to reduce its internal pressure while it does an in-air movement so that it doesn't dribble) simply use G1 to send an E value that is less than the currently extruded length.
G28: Move to Origin
Example: G28
This causes the RepRap machine to move back to its X, Y and Z zero endstops. It does so accelerating, so as to get there fast. But when it arrives it backs off by 1 mm in each direction slowly, then moves back slowly to the stop. This ensures more accurate positioning.
If you add coordinates, then just the axes with coordinates specified will be zeroed. Thus
G28 X0 Y72.3
will zero the X and Y axes, but not Z. The actual coordinate values are ignored.
Unbuffered G commands
The following commands are not buffered. When one is received it is stored, but it is not acknowledged to the host until the buffer is exhausted and then the command has been executed. Thus the host will pause at one of these commands until it has been done. Short pauses between these commands and any that might follow them do not affect the performance of the machine.
G4: Dwell
Example: G4 P200
G20: Set Units to Inches
Example: G20
G21: Set Units to Millimeters
Example: G21
Example: G90
Example: G91
G92: Set Position
Example: G92 X10 E90
Unbuffered M and T commands
M0: Stop
Example: M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller. See also M112.
M20: List SD card
Example: M20
ok Files: {SQUARE.G,SQCOM.G,}
M21: Initialise SD card
Example: M21
The SD card is initialised. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialised for the other SD functions to work.
M22: Release SD card
Example: M22
M23: Select SD file
Example: M23 filename.gco
M24: Start/resume SD print
Example: M24
M25: Pause SD print
Example: M25
M26: Set SD position
Example: M26
M27: Report SD print status
Example: M27
Report SD print status.
M28: Begin write to SD card
Example: M28 filename.gco
M29: Stop writing to SD card
Example: M29 filename.gco
M84: Stop idle hold
Example: M84
M92: Set axis_steps_per_unit
Example: M92 X<newsteps> "Sprinter only"
M104: Set Extruder Temperature (Fast)
Example: M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). See also M109.
Example: M105
Request the temperature of the current extruder and the build base in degrees Celsius. The temperatures are returned to the host computer. For example, the line sent to the host in response to this command looks like
ok T:201 B:117
M106: Fan On
Example: M106 S127
Turn on the cooling fan at half speed. Optional parameter 'S' declares the PWM value (0-255)
M107: Fan Off
Example: M107
Turn off the cooling fan (if any).
M108: Set Extruder Speed
Sets speed of extruder motor. (Deprecated in current firmware, see M113)
M109: Set Extruder Temperature
Example: M109 S190
Set the temperature of the current extruder to 190oC and wait for it to reach that value before sending an acknowledgment to the host. In fact the RepRap firmware waits a while after the temperature has been reached for the extruder to stabilise - typically about 40 seconds. This can be changed by a parameter in the firmware configuration file when the firmware is compiled. See also M104 and M116.
M110: Set Current Line Number
Example: N123 M110
M111: Set Debug Level
Example: M111 S6
#define DEBUG_ECHO (1<<0)
#define DEBUG_INFO (1<<1)
#define DEBUG_ERRORS (1<<2)
M112: Emergency Stop
Example: M112
Any moves in progress are immediately terminated, then RepRap shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller. See also M0.
M113: Set Extruder PWM
Example: M113
M113 S0.7
M114: Get Current Position
Example: M114
Example: M115
sample data from firmware:
This M115 code is NOT yet implemented in any released firmware, and should not be relied upon. An initial implementation was committed to svn for the FiveD Reprap firmware on 11 Oct 2010. Work to more formally define protocol versions is currently (October 2010) being discussed. See M115_Keywords for one draft set of keywords and their meanings.
M116: Wait
Example: M116
M117: Get Zero Position
Example: M117
M118: Negotiate Features
Example: M118 P42
M119: Get Endstop Status
Example: M119
Returns the current state of the configured X,Y,Z endstops. Should take into account any 'inverted endstop' settings, so one can confirm that the machine is interpreting the endstops correctly.
M126: Open Valve
Example: M126 P500
M127: Close Valve
Example: M127 P400
M140: Bed Temperature (Fast)
Example: M140 S55
Set the temperature of the build bed to 55oC and return control to the host immediately (i.e. before that temperature has been reached by the bed).
M141: Chamber Temperature (Fast)
Example: M141 S30
M142: Holding Pressure
Example: M142 S1
M143: Maximum hot-end temperature
Example: M143 S275
Example: M160 S4
When N >= 2, then the E field that controls extrusion requires N+1 values separated by spaces after it like this:
M160 S4
G1 X90.6 Y13.8 E22.4 0.1 0.1 0.1 0.7
G1 X70.6 E42.4 0.0 0.0 0.0 1.0
G1 E42.4 1.0 0.0 0.0 0.0
The second line moves straight to the point (90.6, 13.8) extruding 22.4mm of filament. The mix ratio at the end of the move is 0.1:0.1:0.1:0.7.
The third line moves back 20mm in X extruding 20mm of filament. The mix varies linearly from 0.1:0.1:0.1:0.7 to 0:0:0:1 as the move is made.
The fourth line has no physical effect, but sets the mix proportions for the start of the next move to 1:0:0:0.
M226: Gcode Initiated Pause
Example: M226
Initiates a pause in the same way as if the pause button is pressed.
Example: M227 P1600 S1600
P and S are steps.
Example: M228
Example: M229 P1.0 S1.0
P and S are extruder screw rotations.
Example: M230 S1
M240: Start conveyor belt motor
Example: M240
M241: Stop conveyor belt motor
Example: M241
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
T: Select Tool
Example: T1
Select extruder number 1 to build with. Extruder numbering starts at 0.
RepRap G-Code Summary Table
Command Class Buffered? Parameters Action
G0 G Y Xnnn Ynnn Znnn Ennn Fnnn Rapid move to position specified by parameters
G1 G Y Xnnn Ynnn Znnn Ennn Fnnn Controlled move to position specified by parameters
G4 G N Pnnn Delay for a period of nnn milliseconds
G20 G N none Set distance units for motion and position values to inches
G21 G N none Set distance units for motion and position values to millimeters (default)
G28 G Y Xnnn Ynnn Znnn Move to origin (on specified axes only, if X/Y/Z parameters are present)
G90 G N none Set absolute positioning (for subsequent motion commands) (default)
G91 G N none Set relative positioning (for subsequent motion commands)
G92 G N Xnnn Ynnn Znnn Ennn Define current absolute position
M0 M N none Stop (after completing any buffered commands)
M104 M N Snnn Set current extruder temperature (in Celsius) to value of parameter, and return
M105 M N none Request current extruder and base temperatures (in Celsius)
M106 M N none Set cooling fan off
M107 M N none Set cooling fan on
M108 M N Snnn Set extruder motor speed (DEPRECATED)
M109 M N Snnn Set extruder temperature (in Celsius), and wait for it
M110 M N none Set current line number to Nxxx value preceeding command
M111 M N Snnn Set debug level bitfield to value of parameter (default 6)
M112 M N none Emergency stop (stop immediately, discarding any buffered commands)
M113 M N Snnn Set Extruder PWM (to value defined by pot, or to parameter value if present)
M114 M N none Get Current Position (return current X, Y, Z and E values)
M115 M N none Get firmware version (to be implemented)
M116 M N none Wait for all temperature and slow-changing variables to reach set values
M117 M N none Get Zero Position (return X, Y, Z and E values of endstop hits)
M119 M N none Get Endstop Status (return current X,Y,Z min and max(if configured) endstop values)
M126 M N Pnnn Open Valve and wait for nnn milliseconds for it to open
M127 M N Pnnn Close Valve and wait for nnn milliseconds for it to close
M140 M N Snnn Set build bed temperature (in Celsius) to value of parameter, and return
M141 M N Snnn Set chamber temperature (in Celsius) to value of parameter, and return
M142 M N Snnn Set holding pressure of bed to value of parameter
M143 M N Snnn Set maximum hot-end temperature
M226 M N none Gcode initiated pause
M227 M N Pnnn Snnn Enable Automatic Reverse and Prime (steps parameters)
M228 M N none Disable Automatic Reverse and Prime
M229 M N Pnnn Snnn Enable Automatic Reverse and Prime (rotations parameters)
M230 M N Sn Disable / Enable Wait for Temperature Change
Tn T N none Select Tool n (T0 selects tool 0) (default extruder is 0)
xx can be one of:
ok
rs
ok
start
All this means that every line sent by RepRap to the host computer has a two-character prefix (one of ok, rs, !! or //). The machine should never send a line without such a prefix.
