G-code/zh cn
该页面尝试描述RepRap的固件怎样使用和他们如何工作。该固件的主要目的是用于FFF/FDM方式的增材制造(译者注:国内流行使用 “3D打印”)。其代码用于控制打印头的移动遵守NIST RS274NGC G-code标准,因此RepRap的固件同时可用于CNC机床(或类似)的控制。
正因为如此,许多固件能够被开发出来并不断完善和加入新功能,而他们的开发者不需要参与到之前的开发,甚至不需要了解之前的功能是如何实现,却也能够为这些固件添加他们想要的功能。
- 1 概述
- 2 RepRap G Code Fields
- 3 注释
- 4 Individual commands
- 4.1 Checking 标记代码
- 4.2 Buffered G Commands
- 4.3 Unbuffered G commands
- 4.4 无缓冲的 M 和 T 命令
- 4.4.1 M0: Stop 停止
- 4.4.2 M1: Sleep 睡眠
- 4.4.3 M3: Spindle On, Clockwise (CNC specific)
- 4.4.4 M4: Spindle On, Counter-Clockwise (CNC specific)
- 4.4.5 M5: Spindle Off (CNC specific)
- 4.4.6 M7: Mist Coolant On (CNC specific)
- 4.4.7 M8: Flood Coolant On (CNC specific)
- 4.4.8 M9: Coolant Off (CNC specific)
- 4.4.9 M10: Vacuum On (CNC specific)
- 4.4.10 M11: Vacuum Off (CNC specific)
- 4.4.11 M17: Enable/Power all stepper motors
- 4.4.12 M18: Disable all stepper motors
- 4.4.13 M20: List SD card
- 4.4.14 M21: Initialize SD card
- 4.4.15 M22: Release SD card
- 4.4.16 M23: Select SD file
- 4.4.17 M24: Start/resume SD print
- 4.4.18 M25: Pause SD print
- 4.4.19 M26: Set SD position
- 4.4.20 M27: Report SD print status
- 4.4.21 M28: Begin write to SD card
- 4.4.22 M29: Stop writing to SD card
- 4.4.23 M30: Delete a file on the SD card
- 4.4.24 M40: Eject
- 4.4.25 M41: Loop
- 4.4.26 M42: Stop on material exhausted / Switch I/O pin
- 4.4.27 M43: Stand by on material exhausted
- 4.4.28 M80: ATX Power On
- 4.4.29 M81: ATX Power Off
- 4.4.30 M82: set extruder to absolute mode
- 4.4.31 M83: set extruder to relative mode
- 4.4.32 M84: Stop idle hold
- 4.4.33 M92: Set axis_steps_per_unit
- 4.4.34 M98: Get axis_hysteresis_mm
- 4.4.35 M99: Set axis_hysteresis_mm
- 4.4.36 M101 Turn extruder 1 on Forward / Undo Extruder Retraction
- 4.4.37 M102 Turn extruder 1 on Reverse
- 4.4.38 M103 Turn all extruders off / Extruder Retraction
- 4.4.39 M104: Set Extruder Temperature
- 4.4.40 M105: Get Extruder Temperature
- 4.4.41 M106: Fan On
- 4.4.42 M107: Fan Off
- 4.4.43 M108: Set Extruder Speed
- 4.4.44 M109: Set Extruder Temperature and Wait
- 4.4.45 M110: Set Current Line Number
- 4.4.46 M111: Set Debug Level
- 4.4.47 M112: Emergency Stop
- 4.4.48 M113: Set Extruder PWM
- 4.4.49 M114: Get Current Position
- 4.4.50 M115: Get Firmware Version and Capabilities
- 4.4.51 M116: Wait
- 4.4.52 M117: Get Zero Position
- 4.4.53 M117 in Marlin: Display Message
- 4.4.54 M118: Negotiate Features
- 4.4.55 M119: Get Endstop Status
- 4.4.56 M120: Push
- 4.4.57 M121: Pop
- 4.4.58 M126: Open Valve
- 4.4.59 M127: Close Valve
- 4.4.60 M128: Extruder Pressure PWM
- 4.4.61 M129: Extruder pressure off
- 4.4.62 M130: Set PID P value
- 4.4.63 M131: Set PID I value
- 4.4.64 M132: Set PID D value
- 4.4.65 M133: Set PID I limit value
- 4.4.66 M134: Write PID values to EEPROM
- 4.4.67 M136: Print PID settings to host
- 4.4.68 M140: Bed Temperature (Fast)
- 4.4.69 M141: Chamber Temperature (Fast)
- 4.4.70 M142: Holding Pressure
- 4.4.71 M143: Maximum hot-end temperature
- 4.4.72 M160: Number of mixed materials
- 4.4.73 M190: Wait for bed temperature to reach target temp
- 4.4.74 M200 - Set filament diameter / Get Endstop Status
- 4.4.75 M201 - Set max printing acceleration
- 4.4.76 M202 - Set max travel acceleration
- 4.4.77 M203 - Set maximum feedrate
- 4.4.78 M204 - Set default acceleration
- 4.4.79 M205 - advanced settings
- 4.4.80 M206: set home offset
- 4.4.81 M207: calibrate z axis by detecting z max length
- 4.4.82 M208: set axis max travel
- 4.4.83 M209: enable automatic retract
- 4.4.84 M220:set speed factor override percentage
- 4.4.85 M221: set extrude factor override percentage
- 4.4.86 M226: Gcode Initiated Pause
- 4.4.87 M227: Enable Automatic Reverse and Prime
- 4.4.88 M228: Disable Automatic Reverse and Prime
- 4.4.89 M229: Enable Automatic Reverse and Prime
- 4.4.90 M230: Disable / Enable Wait for Temperature Change
- 4.4.91 M240: Start conveyor belt motor / Echo off
- 4.4.92 M241: Stop conveyor belt motor / echo on
- 4.4.93 M245: Start cooler
- 4.4.94 M246: Stop cooler
- 4.4.95 M300: Play beep sound
- 4.4.96 M301: Set PID parameters - Hot End
- 4.4.97 M303: Run PID tuning
- 4.4.98 M304: Set PID parameters - Bed
- 4.4.99 M420: Set RGB Colors as PWM
- 4.4.100 T: Select Tool
- 5 Proposed EEPROM configuration codes
- 6 Replies from the RepRap machine to the host computer
- 7 Proposal for sending multiple lines of G-code
- 8 Alternatives to G-code
概述
一句能够被RepRap识别的Gcode代码应该是这样子的:
N3 T0*57 N4 G92 E0*67 N5 G28*22 N6 G1 F1500.0*82 N7 G1 X2.0 Y2.0 F3000.0*85 N8 G1 X3.0 Y3.0*33
以上这些句子中的各个符号(当然还有其他符号)的意义将会在下面解释。 The meaning of all those symbols and numbers (and more) is explained below.
以下这个表格可以清楚表明某个语句在哪些固件支持,或尚处于试验性质
Support | FiveD | Teacup | Sprinter | Marlin | Repetier |
yes | automatic | yes | yes | experimental |
Here means:
- yes
- 完全支持.
- experimental
- 实验中的,有一些支持. 但通常情况下,你需要检查下源代码并可能需要做出一些修改。
- automatic
- 自动的,这说明在这个固件中这项命令是自动生成并处理的,因此该命令是不需要的,例如在Teacup(一种固件)你不会用到 power supply on/off (M80/M81)这个命令。
power supply on/off 电源开/关
- no
- 这个固件不支持这项指令.
另外,每一行命令(代码)都以一个<nl>结尾,或者以<nl><cr>结尾,因此,无论是Unix式和windows式的结尾都是有效的。
以下是意译
对于指令Xnnn,其中大写X为指令头,可以是G,M,T,S等,而nnn则是一个整数,或者一个小数,这取决与当时的具体环境。
原文(This section explains the letter-preceded fields. The numbers in the fields are represented by nnn. Numbers can be integers, or can contain a decimal point, depending on context. For example an X coordinate can be integer (X175) or fractional (X17.62), whereas trying to select extruder number 2.76 would make no sense.)
Letter | Meaning |
Gnnn | 标准 GCode 命令, 例如移动到一个坐标点。 |
Mnnn | RepRap定义的命令,例如打开一个冷却风扇。 |
Tnnn | 选择工具代码nnn. 在 RepRap中,工具通常是挤出头(extruder)。 |
Snnn | 命令参数, 例如马达的电压。 |
Pnnn | 命令参数, 频率:1次每毫秒。 |
Xnnn | X坐标, 通常用于移动命令。 |
Ynnn | Y坐标, 通常用于移动命令。 |
Znnn | Z坐标, 通常用于移动命令。 |
Innn | 参数 - 现在仍未使用(定义)。 |
Jnnn | 参数 - 现在仍未使用(定义)。 |
Fnnn | 进料速度 单位: 毫米每分钟 (关系到打印速度)。 |
Rnnn | 参数 - 温度相关。 |
Qnnn | 参数- 现在仍未使用(定义)。 |
Ennn | 挤出长度(单位:毫米)。就像 X, Y 和 Z命令,但这个命令用于控制挤出线材的长度. |
Nnnn | 行码 Line number. 在发送错误情况后,这可以用来重复输入某行代码(命令)。 |
*nnn | 标记码(Checksum). 用于标记错误代码。 |
注释
G Code 注释:
N3 T0*57 ;这是一条注释 N4 G92 E0*67 ; 这也是 N5 G28*22
注释会被RepRap忽略掉,就像空白行,但最好在发送命令之前把注释清除掉,省点流量嘛。。
Individual commands
Checking 标记代码
N 和 *
Example: N123 [...G Code 写在这里...] *71
这是行码和标记码。RepRap的固件会以一个本地计算的值来对比标记码,如果两者值不同,就会要求一个重复的输入
行码和检查码都可以去掉 - RepRap仍会工作, 但它不会做检查. 你必须同时使用,或同时放弃使用.
检查码cs 是通过对对应的一串Gcode cmd(包括它的的行码)的原始字节数据 进行 异或位运算得出的
下面是实例代码:
int cs = 0; for(i = 0; cmd[i] != '*' && cmd[i] != NULL; i++) cs = cs ^ cmd[i]; cs &= 0xff; // Defensive programming...
检查码cs的值即使其*符号右边的十进制数字
RepRap固件希望每次命令的行代码都是逐次增加1的大小,不然的话,它会返回一个错误。当然你也可以发送一个M110命令(详情请看下面)强行重置机器。
译者注:行码和检查码是为了减少信号干扰而存在。
Buffered G Commands
RepRap固件会缓存这些命令。 The RepRap firmware stores these commands in a ring buffer internally for execution. This means that there is no (appreciable) delay while a command is acknowledged and the next transmitted. In turn, this means that sequences of line segments can be plotted without a dwell between one and the next. As soon as one of these buffered commands is received it is acknowledged and stored locally. If the local buffer is full, then the acknowledgment is delayed until space for storage in the buffer is available. This is how flow control is achieved.
G0: Rapid move 快速移动
??? | yes | yes | yes | yes |
Example: G0 X12
这个命令会移动的距离 X = 12 mm. 事实上, 对于RepRap来说,这个命令的效果和G1 X12是一样的。(这条命令本来是为了让那些喜欢走折线路径的老机器走直线这个比较快的路径,所以叫做快速移动)
G1: Controlled move 可控移动
yes | yes | yes | yes | yes |
Example: G1 X90.6 Y13.8 E22.4
从当前的位置点(X, Y) 移动到目的点(90.6, 13.8), 并会在行进过程中挤出22.4mm的打印丝(注意,挤出命令是由E22.4控制的)
RepRap 对于进料速度很敏感. 因此:
G1 F1500 G1 X90.6 Y13.8 E22.4
会先设置 1500毫米每分钟 的进料速度, 然后才会移动(X90.6 Y13.8)并且吐丝.
但是
G1 F1500 G1 X90.6 Y13.8 E22.4 F3000
这串代码却会先设置1500毫米每分钟 的进料速度,然后在移动的时候提升进料速度,直到3000毫米每分钟。
RepRap 可以通过E命令轻易对进料速度进行加/减速,就像对X,Y,Z,E命令一样,这样,机器才能在必要的点吐必要的丝。
提示: 不是所有的固件都支持这项功能(移动在改变进料速度), 例如: 当前的 Marlin 会从一开始就使用新的进料速度,而不会尝试在中途改变它。
第一个例子是在移动时保持固定进料速度,而第二个例子则是在移动中改变进料速度。 因此:
G1 F1500 G1 X90.6 Y13.8 E22.4 F3000 G1 X80 Y20 E36 F1500
这段代码会先先加速进料速度到3000毫米每分钟 减速到1500 毫米每分钟。
吸丝操作,通过反向转动挤出机马达,减少挤出机内部压力,避免在悬空移动时候的吐丝,可以有效减少打印过程中的毛刺现象,具体操作:发送G1 Ennn指令给RepRap 其中nnn的值应当小于当前的值
G28: Move to Origin 移动到原点
Example: G28
该命令会是机器的挤出机复位到原点。准确的说,是一直朝着限位开关(endstops)的方向移动,直到触发限位开关,才会停止移动。需要注意,为了尽早复位,移动过程回不断加速,而到了限位开关之后,它会做一次大约1mm的往返移动,来保证复位操作的精确度。
如果你加上坐标值,那么,只有被加上的坐标值才会被复位 例如:“G28 X0 Y72.3”
只会复位X和Y方向,而不会对高度(Z方向)进行复位。(X和Y后面的数字会被忽略处理)
G29-G32: Bed probing
G29 Detailed Z-Probe
probes the bed at 3 points.
G30 Single Z Probe
probes bed at current XY location.
G31 Report Current Probe status
reports whether Z probe is triggered.
G32 Probe Z and calibrate with FPU
probes the bed at 3 points and updates transformation matrix for bed leveling compensation.
G29 Detailed Z-Probe 详细检查
在3个不同位置对加热床进行检查
G30 Single Z Probe 单一检查
在当前的位置对加热床进行检查
G31 Report Current Probe status 报告检查结果
在3个不同位置对加热床进行检查并依据检查结果做出调整 and updates transformation matrix for bed leveling compensation.
The following commands are not buffered. When one is received it is stored, but it is not acknowledged to the host until the buffer is exhausted and then the command has been executed. Thus the host will pause at one of these commands until it has been done. Short pauses between these commands and any that might follow them do not affect the performance of the machine.
Teacup Firmware buffers G20, G21, G90 and G91.
G4: Dwell 停顿
Example: G4 P200
停顿200毫秒。 在停顿过程中机器仍可以被控制,如挤出头温度。
G10: Head Offset
Example: G10 P3 X17.8 Y-19.3 Z0.0 R140 S205
This sets the offset for extrude head 3 (from the P3) to the X and Y values specified. You can put a non-zero Z value in as well, but this is usually a bad idea unless the heads are loaded and unloaded by some sort of head changer. When all the heads are in the machine at once they should all be set to the same Z height.
Remember that any parameter that you don't specify will automatically be set to the last value for that parameter. That usually means that you want explicitly to set Z0.0.
The R value is the standby temperature in oC that will be used for the tool, and the S value is its operating temperature. If you don't want the head to be at a different temperature when not in use, set both values the same. See the T code (select tool) below.
The NIST G-code standard mentions an additional L parameter, which is ignored.
This command is subject to discussion.
G20: Set Units to Inches
Example: G20
G21: Set Units to Millimeters
Example: G21
Example: G90
Example: G91
G92: Set Position
Example: G92 X10 E90
无缓冲的 M 和 T 命令
M0: Stop 停止
Example(例子): M0
RepRap 会终止任何动作, 然后关机。所有的马达和加热器都很被关掉,你需要点击reset按钮来重启主控制器 See also M1, M112.
M1: Sleep 睡眠
Example: M1
RepRap 会终止任何动作, 然后关机。所有的马达和加热器都很被关掉,你仍可以发送 G或 M 命令来唤醒它 See also M0, M112.
Example: M3 S4000
Example: M4 S4000
Example: M5
The spindle is turned off.
Example: M7
Example: M8
Example: M9
Example: M10
Example: M11
Example: M17
Example: M18
- Is this not the same as M84? -- MrAlvin 05:53, 20 September 2012 (UTC)
M20: List SD card
Example: M20
ok Files: {SQUARE.G,SQCOM.G,}
Example: M21
The SD card is initialized. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialized for the other SD functions to work.
Example: M22
M23: Select SD file
Example: M23 filename.gco
Example: M24
M25: Pause SD print
Example: M25
Example: M26
Example: M27
Report SD print status.
Example: M28 filename.gco
Example: M29 filename.gco
Example: M30 filename.gco
filename.gco is deleted.
M40: Eject
See also M240 and M241 below.
M41: Loop
Example: M41
- When you press the reset button,
- When the build material runs out (if your RepRap is set up to detect this), and
- When there's an error (such as a heater failure).
M42 in ???
Example: M42
If your RepRap can detect when its material runs out, this decides the behaviour when that happens. The X and Y axes are zeroed (but not Z), and then the machine shuts all motors and heaters off. You have to press reset to reactivate the machine. In other words, it parks itself and then executes an M0 command (q.v.).
M42 in Marlin/Sprinter
Example: M42 P7 S255
M42 switches a general purpose I/O pin.
M42 in Teacup
Not needed. General purpose devices are handled like a heater, see M104.
Example: M43
M80: ATX Power On
Example: M80
Note: some firmwares, like Teacup, handle power on/off automatically, so this is redundant there.
M81: ATX Power Off
Example: M81
Example: M82
makes the extruder interpret extrusion as absolute positions.
Example: M83
makes the extruder interpret extrusion values as relative positions.
M84: Stop idle hold
Example: M84
Example: M92 X<newsteps> Sprinter and Marlin
Example: M98
Proposed for Marlin
Example: M99 X<mm> Y<mm> Z<mm> E<mm>
Proposed for Marlin
M101 in Teacup firmware
If a DC extruder is present, turn that on. Else, undo filament retraction, which means, make the extruder ready for extrusion. Complement to M103.
M101 in other firmwares
Deprecated. Regarding filament retraction, see M227, M228, M229.
Deprecated.
M103 in Teacup firmware
If a DC extruder is present, turn that off. Else, retract the filament in the hope to prevent nozzle drooling. Complement to M101.
M103 in other firmwares
Deprecated. Regarding extruder retraction, see M227, M228, M229.
Example: M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). See also M109.
M104 in Teacup Firmware
Example: M104 P1 S100
Set the temperature of the device attached to the second temperature sensor to 100 °C.
Example: M105
Request the temperature of the current extruder and the build base in degrees Celsius. The temperatures are returned to the host computer. For example, the line sent to the host in response to this command looks like
ok T:201 B:117
M106: Fan On
yes | yes | yes |
Example: M106 S127
Turn on the cooling fan at half speed.
Mandatory parameter 'S' declares the PWM value (0-255). M106 S0 turns the fan off.
M106 in Teacup Firmware
Example: M106 P2 S255
M107: Fan Off
Deprecated. Use M106 S0 instead.
Sets speed of extruder motor. (Deprecated in current firmware, see M113)
??? | not needed | see text | yes | ??? |
M109 in Teacup
M109 in Marlin, Sprinter (ATmega port)
Example: M109 S185
M109 in Sprinter (4pi port)
Example: M109 S185 R240 //sets extruder temperature to 185 and waits for the temperature to be between 185 - 240.
??? | not needed | ??? | ??? | ??? |
Example: M110 N123
Example: M111 S6
#define DEBUG_ECHO (1<<0) #define DEBUG_INFO (1<<1) #define DEBUG_ERRORS (1<<2)
Example: M253
Debug |
Example: M112
Example: M113
M113 S0.7
Example: M114
Example: M115
sample data from firmware:
M116: Wait
Example: M116
Example: M117
Example: M117 Hello World
This causes the given message to be shown in the status line on an attached LCD. The above command will display Hello World.
Example: M118 P42
yes | yes |
Example: M119
M120: Push
- Current feedrate, and
- Whether moves (and separately extrusion) are relative or absolute
M121: Pop
M126: Open Valve
Example: M126 P500
M127: Close Valve
Example: M127 P400
Example: M128 S255
Example: M129 P100
yes |
Example: M130 P 0 S 8.0 # Sets heater 0 P factor to 8.0
yes |
Example: M130 P 1 S 0.5 # Sets heater 1 I factor to 0.5
yes |
Example: M130 P 0 S 24 # Sets heater 0 D factor to 24.0
yes |
Example: M130 P 1 S 264 # Sets heater 0 I limit value to 264
yes |
Example: M134
Debug |
Example: M136 P1 # print heater 0 PID parameters to host
Example: M140 S55
Set the temperature of the build bed to 55oC and return control to the host immediately (i.e. before that temperature has been reached by the bed).
Example: M141 S30
Example: M142 S1
Example: M143 S275
Example: M160 S4
When N >= 2, then the E field that controls extrusion requires N+1 values separated by spaces after it like this:
M160 S4 G1 X90.6 Y13.8 E22.4 0.1 0.1 0.1 0.7 G1 X70.6 E42.4 0.0 0.0 0.0 1.0 G1 E42.4 1.0 0.0 0.0 0.0
The second line moves straight to the point (90.6, 13.8) extruding 22.4mm of filament. The mix ratio at the end of the move is 0.1:0.1:0.1:0.7.
The third line moves back 20mm in X extruding 20mm of filament. The mix varies linearly from 0.1:0.1:0.1:0.7 to 0:0:0:1 as the move is made.
The fourth line has no physical effect, but sets the mix proportions for the start of the next move to 1:0:0:0.
obsolete, see M116 | yes | yes |
Example: M190 S60
yes |
M200 sets the filament diameter.
Question: what does a firmware do with filament diameter? Has this an effect on how much an E command moves the extruder motor? --Traumflug 11:34, 14 October 2012 (UTC)
in units/s^2 for print moves (M201 X1000 Y1000)
that your machine can sustain (M203 X200 Y200 Z300 E10000) in mm/sec
Note: this should be in units/minute, just like the F code.
Example: M206 X10.0 Y10.0 Z-0.4
Example: M207
Example: M208 X250 Y210 Z180
Example: M209 S1
Example: M220 S80
S<factor in percent>- set speed factor override percentage
Example: M221 S70
S<factor in percent>- set extrude factor override percentage
Example: M226
Example: M227 P1600 S1600
P and S are steps.
Example: M228
See also M227.
Example: M229 P1.0 S1.0
Example: M230 S1
Debug: Echo off |
Example: M240
Debug: Echo on |
Example: M241
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
Usage: M300 S<frequency Hz> P<duration ms>
Example: M300 S300 P1000
PID |
Example: M301 P1 I2 D3 C5
Sets Proportional, Integral and Derivative values for hot end, the value C refers to an extrusion rate.
Alternate implementation
Example: M301 W125
PID | PID |
Hotend Usage: M303 S<temperature> C<cycles> Bed Usage: M303 E-1 C<cycles> S<temperature> Example: M303 C8 S175
Generate Proportional, Integral and Derivative values for the hotend or bed (E-1). Send the appropriate code and wait for the output to update the firmware.
PID |
Example: M304 P1 I2 D3
Sets Proportional, Integral and Derivative values for bed
Example: M420 R255 E255 B255
T: Select Tool
Example: T1
Select extruder number 1 to build with.
The sequence followed is:
- Set the current extruder to its standby temperature specified by G10 (see above),
- Set the new extruder to its operating temperature specified by G10 and wait for all temperatures to stabilise,
- Apply any X, Y, Z offset for the new extruder specified by G10,
- Use the new extruder.
Selecting a non-existent tool (100, say) just does Step 1. above. That is to say it leaves all tools in their standby state. You can, of course, use the G10 command beforehand to set that standby temperature to anything you like.
If the Z value changes in the offsets and the head moves up, then the Z move is made before the X and Y moves. If Z moves down, X and Y are done first.
After a reset extruders will not start heating until they are selected. You can either put them all at their standby temperature by selecting them in turn, or leave them off so they only come on if/when you first use them. The M0, M1 and M112 commands turn them all off. You can, of course, turn them all off with the M1 command, then turn some back on again. Don't forget also to turn on the heated bed (if any) if you use that trick.
Extruder numbering starts at 0.
Marlin uses these codes to manipulate EEPROM values.
M500: stores paramters in EEPROM
M501: reads parameters from EEPROM
If you need to reset them after you changed them temporarily
M502: reverts to the default "factory settings".
You still need to store them in EEPROM afterwards if you want to.
M503: Print settings
xx can be one of:
ok
rs
ok
start
Exceptions: Marlin 1.0.0 Gen6 Firmware does not follow the two character rule. 'rs' is actually 'Resend' and '!!' is 'Error'.
Example Lines:
- Error: Line Number is not current line + 1. Last Line: 7
- Resend: 8
- Writing to File: print.gco
- Done saving file.
- File opened:print.gco Size:22992
- File selected
Problem to solve
Each line of G-code sent from the host to the controller is answered with an ok before the next line can be sent without locking communcations up. This makes operations very slow, as the usual USB-TTL converters and probably also the host's operating system drivers come with substantial latency, often 10 milliseconds.
For more details on this proposal, and some suggested solutions, and comments please see GCODE_buffer_multiline_proposal
- Main article: Firmware/Alternative#alternatives to G-code
- Wikipedia: STEP-NC: "STEP-NC was designed to replace ... G-codes ... adding tolerance data ... [with a] XML format."
- Elegant multispline motion controller "will not use G-code. It will use a custom language based on cubic Bezier curves. This allows for much better description of arcs and will result in much higher quality prints with a much lower data throughput requirements."
