Klinge Hotend
Revision as of 09:22, 8 January 2014 by Santafesino (talk | contribs)
This page will show information referred to a hotend for reprap 3D printers. The hotend has been developed in Argentina by Santafesino. Introduction This is an all metal hotend and was designed to be not only functional but also easy to fabricate and assemble. As almost any all metal hotend in the world it uses active cooling. It's intended to be mounted in any extruder body that can hold a J-Head, using the same M3 bolts.
Advantages: It's extremely short, especially for an all metal hotend, so it allows the printer to print higher parts. It uses an air duct so the air flow needed to it's own cooling doesn't affect the heated bed or the part being printed.
Disadvantages: I consider using active cooling a disadvantage, comparing to other hotend that doesn't need this.
