Kludgebot
Revision as of 14:07, 22 October 2010 by Buback (talk | contribs) (changed status to experimental (status should be added to the template so that everything doesn't fall into 'unknown'))
These are good resources for creating wiki pages.
Example and Columbus
--Sebastien Bailard 07:23, 10 September 2010 (UTC)
Example Development
Release status: experimental
documenting a generic tool/artpiece
This is 600 pixels wide, and on the left.
Kludgebot SOLID MODEL ASSEMBLY These are CAD files for the Solid Model Assembly .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)
Kludgebot CAD FILES FOR PARTS These are CAD files for each part. .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)
Kludgebot EVEN MORE FILES These are are even more files. .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)|-
Kludgebot SOLID MODEL ASSEMBLY This is the final finished machine N/A --Example User 12:00, Tomorrow's Date, 20xx (UTC)
Please edit this and click the links to put in your own files! --Sebastien Bailard 08:34, 10 September 2010 (UTC)
Cost
<maxbots> Totale for the frame including all hardware was like $180.
Personal Thoughts
Design goal: This is designed to be cheap and easily assembled by anyone with a minimal toobox. It should require no more than a screwdriver, hacksaw and file, though other tools may be required in the end. The printed part list is being kept to a minimum, so those of you who don't already have printers won't have to shell out $2-300 for a set of parts to get started. The majority of the parts are either readily available from multiple sources or are easily sourced from reputable vendors who ship globally with reasonable shipping costs. Whenever possible, multiple sources will be listed, and if you know of a source that I am missing, please list it here or in the talk page. For those of you who DO have printers, as many of the parts as possible are available in printed equivalents. The goal is to be as flexible as possible.
Projected final cost including the entire mechanical stage, but not including motors, extruder, or electronics is under $200, and that could be reduced under $150 if you have access to a printer to increase the printed part content.
This is not designed to be a bridge bot that you use to make some better bot. While I am designing it to be as simple to get started, it is designed as a first class bot and a true reprap, not a repstrap (though I call it a "Vitamin-Rich RepRap" since I favor off-the-shelf components over printed ones where it makes economic sense to do so).
As of today (2010/10/23) the basic design is roughly 50-75% done. I am working hard to have the first prototype finished within the next month or two. Once I finish the design, all files will be released and far more documentation will be available.
More Examples
