LaserCut Mendel Assembly
These assembly instructions are incomplete and have been posted by a customer rather than anyone associated with the sale of LaserCut Mendels. You may also wish to refer to the LaserCut Mendel Assembly Blog which shows some assembly pictures from another customer (in that case, only the laser cut parts are from techzone).
Extruder
My extruder arrived mostly assembled. Here are a couple of pictures of it. The small drive gear is very wonky. It looks like the laser cutter was not cutting vertically when it was produced. I needed to put 2 washers between the bearing and the large gear to ensure that the knurled part of the bolt aligned with the bearing, extruder nozzle and filament hole.
I am unsure of how to mount this to the X Carriage and also how the extruder nozzle is supposed to attach to it. It screws in to the bottom, but the fit is fairly loose and there is nothing to screw it up against.
File:LaserCutExtruderAssembled1.jpg:500 File:LaserCutExtruderAssembled2.jpg:500 File:LaserCutExtruderAssembled3.jpg:500 File:LaserCutExtruderAssembled3.jpg:500
X Axis
X Carriage
Tip: You will want to tighten two of the screws on the belt clamps (the ones shown at the bottom in the picture below) sufficiently to allow you to clamp the belt by only tightening screws at the top. This is because access to the cap head of the bottom screws is blocked by the bearing mounts once they are installed.
The X belt supplied by TechZone was barely long enough to go around the assembly. I installed the axis ends so that the smooth rods were almost touching the bearings (less than 1mm clearance). I still had to cut the belt and just clamp the ends on the x carriage to make it long enough to go round the assembly. Caution: This picture shows the X Carriage installed on the X Axis upside down (it shows the top of the X Carriage and the bottom of the X motor and 180 bearing mounts).
Y Axis
Y Idler
Be warned that you probably need an additional washer against each bearing to allow the belt enough space for smooth running between the mudguard washers.
Y Motor
Y 360 Bearing
Y 180 Bearing
Y Chassis
I have found this to be the trickiest bit to work out without instructions, so I have left it till last. Consequently, I have used all of the shorter M4 screws that come with the kit and don't seem to have the right screws left to do this job (All I have left are lots of the M4x40 screws that only have thread on the last half). I think you are supposed to use the M4x30 Phillips Pan head screws to mount the Y 360 Bearing and the Y 180 Bearing to the frog plate?
Z Axis
Z Leadscrew Base (one with opto)
You will need 2 of these assemblies, only one of them has the opto mount.
Name | Qty /w opto | Qty /wo opto | Type |
Z Leadscrew Base | 1 | 1 | Laser Cut Part |
Opto Spring | 1 | 0 | Laser Cut Part |
Opto Holder | 1 | 0 | Laser Cut Part |
Bearing | 2 | 2 | Hardware |
M4x40 | 3 | 2 | Fastener |
M4 Washer | 9 | 8 | Fastener |
M4 Mudguard Washer | 4 | 4 | Fastener |
M4 Nut | 3 | 2 | Fastener |
Z Motor
Z Tensioner
Frame
Frame Sides
Left Side
BOM
Name | Qty/assembly | Type |
M8 Nut | 14 | Fastener |
M8 Washer | 14 | Fastener |
370mm M8 Threaded Rod | 3 | Hardware |
corner vertex | 3 | Laser Cut Part |
Z Leadscrew base | 1 | Laser Cut Part |
Z Motor Bracket | 1 | Laser Cut Part |
You will also need a measurement jig to get the distance between the corner vertices the same. I created a jig using one of the other bits if M8 rod, 4 nuts and 2 washers. I assembled the jig so that the outside of the two washers was 290mm apart. Then used it when tightening the nuts on the vertex pieces to ensure the spacing was right.
Right Side
BOM
Z Tensioner Bracket | 1 | Laser Cut Part |
Assembled Frame
The pictures below show too many nuts on the front and rear bars. If you get the kit and do it this way, you will not have enough nuts. I was following the official Mendel build pics and it looks like they have too many nuts too (http://reprap.org/wiki/File:Frame-end-assembly.PNG).
Z Axis Installation
This is the same as the standard Mendel. Refer to the Mendel_frame#Installation_of_X-axis instructions.
Y Axis Installation
This shows the Y bars installed before the screws and M8 nuts are tightened. You can also see the rubber feet that I have epoxied to the four base vertices (these do not come as part of the TechZone kit).
Mechanical Construction Issues
I have assembled the Y carriage and installed it, but it looks like there is very little room for the Y carriage print bed mounts to fit between the base vertex pieces. Is the Y carriage supposed to have the full range of movement? Or should it be stopped before it passes between the frame vertices? I went ahead and used a hacksaw to chop a couple of millimeters of each of the print bed supports.
Printbed problem
The Aluminium print bed sits (or is supposed to sit) in a routed recess in the laser cut printbed. Unfortunately, mine was too big for the routed recess. I needed to manually hack the routed recess with a stanley knife to make it large enough for the aluminium insert.
Once the bed is sitting flush in the recess, the width of the bed is still causing issues because it is partially obscuring the holes for mounting the bed to the Y Carriage. The kit creator suggests notching the printbed to allow room for the screws. The following pictures shows before and after the hole notching:
