Budaschnozzle
Revision as of 16:09, 8 September 2011 by Steven-AlephObjects (talk | contribs)
BudaSchnozzle
Release status: Working
Truly free/libre hot end
GPLv3
Intro
Features
  • Aluminum Block Resistor Hotend
  • Easily assembled and torn down with no glue or ceramic
  • Wire Strain Relief
  • Includes machined aluminum and steel parts, and laser cut wooden parts
Specs
  • Size: (H,W,L) 55mm, 40mm, 40mm
  • Aluminum block resistor
  • Aluminum and copper heatsink
  • PEEK GF30 insulator
  • PTFE inner sleeve
  • Laser cut hard wood plates
  • Machined stainless steel back-up plate
Special Notes
A thermal table has been created for the Honeywell 135-104LAG-J01 thermistor for use with the Buddhaschnozzle. The thermal table is included in the Sprinter firmware and is used by selecting thermistor 7 in the Configuration.h file in Sprinter. Change the line "#define THERMISTORHEATER 1" to "#define THERMISTORHEATER 7"
Source
FILE TYPE DESCRIPTION DOWNLOAD
Bill of Materials Spread sheet Spread sheet of bill of materials .ods
Heater Block 2D & 3D CAD drawings CAD drawing for the heater block .pdf, .SLDDRW, .SLDPRT
Nozzle 2D & 3D CAD drawing CAD drawing for the nozzle .pdf, .SLDDRW, .SLDPRT
Peek Isolator 2D & 3D CAD drawing CAD drawing for the PEEK isolator .pdf, .SLDDRW, .SLDPRT
Upper Plate 2D & 3D CAD drawing CAD drawing for the Upper Plate .pdf, .SLDDRW, .SLDPRT
Lower Plate 3D CAD drawing CAD drawing for the Lower Plate .SLDPRT
Backup Plate 2D & 3D CAD drawing CAD drawing for the Backup Plate .pdf, .SLDDRW, .SLDPRT
Copper Heatsink 2D & 3D CAD drawing CAD drawing for the Copper heatsink .pdf, .SLDDRW, .SLDPRT
Budaschnozzle Mount 3D CAD model and drawing 3D CAD model for the Budaschnozzle mount .stl, .SLDPRT
