MKS TB6600
Revision as of 06:10, 29 November 2014 by Glenn (talk | contribs) (catchg)
Template:MKS TB6600
Release status: Working
Stepper Driver
Summary
High performance, cost-effective. Automatic idle-current reduction. Supply voltage up to 45V DC Output current up to 4.5A. Can be used on ramps(need mks cd),mks gen and so on
Features
  • PWM chopper-type single-chip bipolar sinusoidal micro-step stepping motor driver.
  • BiCD 0.13 (50 V) process, Lower Ron: 0.4 Ω(typ.).
  • Output withstand voltage: VCC = 50 V.
  • Output current: IOUT = 5.0 A (absolute maximum ratings, peak, within 100ms);IOUT = 4.5 A (operating range, maximal. value);More Stepper motors
  • Thermal shut down (TSD) protection.
  • Under voltage lock out (UVLO) protection.
  • Over-current detection (ISD) protection.
  • Double input port: Anti-reverse structure IDC haeder( 8pin symmetrical input) & HT-396-4pin input (suit for DIY).
  • Stepless adjustable reference voltage.
  • Compatible the CNC Stepper Motor.
  • Offer an solution to change your CNC to 3D Printer.
  • Board size: 50.5*50mm ; Carry 50*50*23mm aluminum Heat sink which build-in fix hole and connection hole.
  • Auto half current, energy conservation.
  • Photoelectric-isolation used in the input port,compatible more drive Level.
  • Programmable micro step - 1/1, 1/2A, 1/2B, 1/4, 1/8, 1/16.
  • Affordable price.
Settings of Driver
Connect direct
Connect with MKS CD
How to get it
MakerBase.com.cn
