Mendel Variations/Catalyst
Description | a Mendel variation distributed from profounddevices.com
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Working Notes
The design creator has made a number of videos available, as well as assorted assembly notes. He also has made control software which should probably be handled separately.
The design is notable for its simplicity. Belts are eliminated. The formed parts are designed to be easily produced in small batches and accept roughness derived from their production. A definite effort has been made to reduce the number and variety of components.
Discussion
Forum threads
Software
Onboard
Arduino Loader, link to current version
Arduino File, link to current version
Host
Motor Controller Application, link to current version.
This version is suitable for testing the motors. Updates are scheduled.
Drawings
Circuit Diagrams
Two versions are posted.
Which is correct?
Assembly
Assembly Notes
Electrical Components
Power Supply
Electronics
Sensors
- Limit Switches (3)
- Temperature Sensor
- Wire, Aluminum
- --User Circuit--
- --Circuit Components--
Motors
Stepper Motors (5)
- X-Axis Stepper
- Y-Axis Stepper
- 2 Z-Axis Steppers assembly
- Feeder Stepper
Wire
CAT5 cable, separated
Extruder
- Insulated Ni-Chrome Wire
- PTFE Insulator
- Brass Heated Barrel
- Brass Tool Tip
- Wire, Aluminum
- --User Circuit--
MechanicalComponents
Frame
- Threaded Rod (6)
- Mendel Vertices (12)
- Bolts (48)
- Washers (48)
Mounting Board
- Board Mount
- Screws (6)
Bowman Cable
- Tube
- Nuts (2)
X-Axis Gantry
- X-Axis Carriages (2) assembly
- Bolts (4 x 2)
- Inner Plate (1 x 2)
- Washers (8 x 2)
- Bearings (8 x 2)
- Bolts (8 x 2)
- Outer Plate (1 x 2)
- Screw (4)
- Washers (4)
- Nuts (4)
- Hollow Rod (2)
- X-Motor Mount (2)
- Screw (4)
- Washers (4)
- Nuts (4)
- Extruder Assembly
- Extruder Mount assemblystill photos
- Negative-X Extruder Mount
- Positive-X Extruder Mount
- Horizontal Extruder Mount
- Extruder Frame assembly
- 3-Hole Washers (2)
- Screws(2)
- Nuts (2)
- Bowman Mount
- Bowman Capture Mount
- Bolt
- Nut
- Washer
- Drive Nut Catch
- Drive Nut Catch Plate
- Bolts (2)
- Nuts (2)
- X-Axle
- Threaded Rod
- Flywheel
- Bolts (3)
- Lock Washer
- Tube, motor adapter
- Limit Switch Mountassembly
Y-Axis
Y-Axis Gantry
- Y-Axis Mounts (8)assembly
- Hollow Rod (2)
- Y-Axis Table assembly, older - part 1, older - part 2
- Positive-Y Table Mount
- Negative-Y Table Mount
- Screws (4)
- Nuts (6)
- Washers (2)
- Lock Washers (2)
- Bolts (4)
- Nuts (16)
- Springs (4)
- Washers (4)
- Build Surface
- Drive Nut Catch
- Bolts (2)
- Nuts (2)
Y-Axis Motor Mount Assembly assembly
- Y-Axis Motor Mount Lower Assembly
- Y-Axis Lower Motor Mount
- Bolts (2)
- Washers (2)
- Nuts (2)
- Y-Axis Motor Mount Upper Assembly
- Y-Axis Upper Motor Mount
- Bolts (4)
- Washers (4)
- Nuts (4)
- Bolt
- Washer
- Lock Washer
Y-Axle
- Threaded Rod
- Flywheel
- Bolts (3)
- Lock Washer
- Bolts (2)
Z-Axis
Z-Axle (2) assemblyassembly- part 2
- Threaded Rod (1 x 2)
- Tube (1 x 2) motor adapter
- Nut (1 x 2)
Z-Motor Mount Assembly (2) assembly
- Z-Motor Mount (2 x 2)
- Bolts (2 x 2)
- Washers (2 x 2)
- Nuts (2 x 2)
- Bolts (4 x 2)
- Lock Washers (2 x 2)
- Washers (2 x 2)
- Bolt (1 x 2)
- Nut (1 x 2)
Hollow Rod (2) Z-Rod Top Mount (2) assembly
- Rod Coupling Nut (2 x 2)
- Z-Rod Mount (2 x 2)
- Bolts (2 x 2)
- Limit Switch Mount assembly
Feeder
assembly, previous Feeder Motor Rotor
- Bolt
- Washer
- Bearing
- Washer
- Plumbing Seat Washer gasket
- Nut
- Tube motor adapter
- Superglue
- Bowman Mount
- Bolt
- Nut
- Washer
- Pinch Rotor
- Bolt
- Bearing
- Washer
- Washers (2)
- Nut
- Bolts (4)
- Nuts (16)
- Feeder Rotor Plate
- Feeder Center Plate
- Feeder Motor Base Plate
- Washers (2)
- Bolts (2)
- Washers (2)
- Nuts (2)
Tooling
Description of tooling requirements.
Process
What is making the part like?
