Mondrian Buyers Guide
Revision as of 05:00, 28 June 2015 by XoanSampaiño (talk | contribs) (→Z cube: Update BOM to v3 corners base)
Mondrian Documentation
Temp. BOM
XY-gantry
- 5 20x20mm extrusions of the desired length
- 4 upper corner.stl
- 6 m4x8
- 6 T-nut
- 1 m3x25
- 2 y-sliders.stl
- 1 nema14
- 1 pulley
- 4 m3x30 bolt
- 2 603zz bearing
- 6 zip-ties
- one length of belt (extrusion length + 40mm)
- 1 x-carriage.stl
- 1 nema14
- 1 pulley
- 4 m3x30 bolt
- 2 603zz bearing
- 6 zip-ties
Z cube
- bottom plate
- 4 20x20mm extrusions of the desired length
- 1 nema 17
- 4 m3x12
- 4 m3 large washer
- 2 m3x25 "idler"
- 3 m3 washer
- 2 623zz bearings
- 1 m3 large washer
- 1 m3 nylock
- a closed belt (extrusion length*4 +a little margin) (e.g.: ~1300 mm for a machine based on 300mm extrusion [1] (UK RS Stock Code: 474-5252) or 950 for a 200mm version [2])
- 4 corner-base
- 1 20x20mm extrusion of the desired length
- 1 m5 threaded rod (lenght of Z extrusion +25mm, e.g.: 325mm for a MXX3)
- 1 T2.5 pulley 16mm length
- 2 m5 washer
- 2 m5 nut (nylon)
- 2 605ZZ bearing (5x14x5 mm)
- 2 T-nut
- 2 M4x8
- rear-plate
- power supply
- 2 m3x8
- 2 m3 nut
- power plug
- 2 m3x8
- 2 m3 nut
- electronic board
- minitronic : 4 m3x12 + +8 m3 nut + 4 m3 nylock
- power supply
- bed-plate
- 4 Z-slider.stl
- 8 m5 nut nylon
- 4 m3x12
- 4 m3 nut
Extruder
- 2 extruder-idler.stl
- 3 m3x8
- 1 nema 14
- 1 drive-gear
- 1 m3x20
- 1 603zz bearing
- 2 m3 washer
- 2 m3x35
- 2 springs
- 2 m3 nut
- 1 ma-12-03-m5 pneumatic fitting
- 1 m5 nut
FoldaRap Dual Hotend
- 2 reprappro one piece nozzle (and a short lenght of ptfe tube)
- 2 heater block
- 2 thermistor
- 2 heater cartridge
- 1 heatsink block
- 2 ma-12-03-m5 pneumatic fitting
- 1 heatsink
- 1 40mm fan
- 2 500mm ptfe tube (bowden)
Other Tools
- plotter
- j-head
- prusanozzle
- bio-printing
Shopping list
- Linear bearing pads
- you are lucky if you're in the US -> 80/20 store
- for EU, you'll find some resellers like westgroup.co.uk (I listed some spares on emakershop too)
- QJFM 02-20 [3]
- PEI sheet [6]
