P2f
Revision as of 11:31, 14 September 2013 by KalleP (talk | contribs)
P2F
Mendel variation made in China
200
YesRap P2F is a completely redesigned 3D printer, based on concepts from Prusa i3, MendelMax, Ultimaker, Open Rail, etc. Thank all of them!
Overview
P2F is a 3D printer designed by YesRap in China. The main frame is constructed using laser cut plywood. The linear bearing system, based on Open Rail and MakerSlide, is also completely redesigned using laser cut steel plates, bent and mounted on plywood frame. The expected initial public release is March 15, 2013.
Main Improvements
  1. Mostly preassembled -------- Easy and fast assembly, about 5 hours for inexperienced user from opening of package to printing.
  2. Plywood reinforced by aluminum profile -------- strong, light weight and easy assembly.
  3. Mostly maintenance free ------- no need for lubricant.
  4. Replaceable extruder nozzle ------- less headache for clogged nozzle plus also easily switchable nozzle sizes.
  5. Light weight -------- 6.5kg, lower shipping cost.
  6. High speed ----------- travel = 300mm/s print = 200mm/s.
  7. Redesigned open rail ------- all benefits from open rail design, plus ???
  8. Low noise ------------  ??db
Parts List
Electrical Parts
Quantity Part Picture
1 Sanguinololu 1.3A with ATmega1284P + USB or Bluetooth
1 Standard SD Card Slot
1 A4988 Stepper Motor Driver
1 DC Power Supply 350W 12V 29A
1 Heated Bed with LED and Temperature Sensor
Mechanical Parts
Plywood Parts List
1 FrameY
1 FrameZ File:Frame Z |
2 Frame_Back side File:Frame side |
2 Frame_Bottom side File:Frame bottom |
1 Frame_Top File:Frame top |
Steel Parts List
1 FrameX
Aluminum Parts List
1 Motor Y Mount
6 YesRail(R)
Additional Parts List =
1 Extruder
1 Hot End
1 Borosilicate Glass
1 BudaschNozzle V1.1
Assembly Procedure
Frame setup Z-motor z rods z_belt extruder Bowden bed electronics wires
Main Frame
Order todo Picture
1 cross frame_Z and frame_Y Frame zy cross.jpg |
2 insert two back side File:Add back side.jpg|
Bottom Frame
Order todo Picture
1 Mount Y motor
2 Mount Y-home sensor
3 Mount Y-home sensor
4 Mount AC power socket to left bottom
5 join two bottom peaces and Y-motor
6 join two bottom frame to main frame
Mount YesRail
use m3*25 screw,
Order todo Picture
1 Mount YesRaail on Y
2 Mount YesRail on Z
Links
[1] YesRap's home page.
[2] YesRap's taobao (equivalent to eBay) page.
[3] A video showing the printer printing using ABS.
[4] Photo gallery.
