Panelolu
Revision as of 15:14, 15 January 2014 by T3P3 (talk | contribs) (Updated info about Panelolu2)
Version specific info
Panelolu | Panelolu2
Panelolu
RepRap electronics controller, with LCD, SD card, reset and rotary encoder.
GPL
Introduction
You can use this page as a guide for wiring up any SD card/LCD/encoder/reset combination to your electronics. Instructions here are for Sanguinololu, RAMPS and Printrboard, but it should be easily adapted for others like Melzi, RAMBo and Azteeg.
Panelolu is an LCD and rotary encoder with a click button control solution which derives from the PanelMax Prusa by tommyc. It allows control of a 3D printer running Marlin firmware and Sanguinololu or similar electronics directly without having to have a computer connected. Stand-out features are the ability to start and stop prints, control print speed while printing and change many calibration settings - saving these to the memory on the ATmega 1284 (EEPROM) so they are persistent if you turn the printer on and off. Continuing with tommyc's design the panelolu has mounting brackets for the Prusa mendel or other threaded rod based printers. The brackets are separate from the enclosure so they can simply be replaced with a different design for a different mounting solution.
The Panelolu is designed to use as little soldering as possible (if the breadboard comes pre-assembled and the LCD with plugs fitted then no soldering is required at all) and to allow an easy upgrade path. It uses the SDSL card reader, so if you already have one there is no need to get another. Rather than soldering wires directly to the LCD, headers have been fitted so future changes can re-use the LCD simply.
The schematic is a little tangled but each wire can be traced from the Sanguinololu - through the 24 way IDC connector and ribbon cable to its final destination in the enclosure. A 22 way IDC connector would have worked fine but they are hard to find so we use a 24 way and don't plug in pins 23 and 24.
Where to buy
The Panelolu has been superseded by the Panelolu2 so kits are no longer available however parts can be self sourced and these instructions used to assemble one.
Files
The enclosure is on thingiverse.com, as an OpenScad file and STL.
Assembly instructions
These instructions are from Think3DPrint3D blog.
Step 1 - Tools and components
Tools
The Panelolu can be assembled with a few basic tools:
  • Allen Key for the M3 socket head fastenings
  • Cross head screw driver for the SDSL and breadboard mounting screws
  • Small needle nose pliers for crimping connectors
  • wire cutters
If you are assembling the breadboard you will also need a soldering iron and solder.
BOM
The components are as in the picture below:
  • Rotary encoder - Farnell UK
  • Reset switch (generic) - RS online UK
  • Potentiometers (generic) - RS online UK
  • LCD Panel - Hitachi HD-44780 based 4x20 column display, or clone/something similar. You can use 2x16 or 2x20, though the enclosure may not fit. The one used here is something like Farnell UK; the PCB is 98mm x 60mm, the display area is 76mm x 25.2mm.
Most LCD panels come with mounting holes for M2.5 screws, but I prefer to drill these out slightly and use M3, the enclosure has M3 holes but they should work ok with M2.5 if you prefer to use that.
Step 2 - Assemble the breadboard and the LCD connectors.
Circuit boards are available - see Think3dPrint3d circuit boards - and T3dP3d supply them with their kits. If you get the kit, ignore this step and move to step 3 - the breadboard instructions below are only necessary if you want to source your own components.
NOTE: these instructions are for a the breadboard assembled with the click encoder on the right of the panel as you look at it from the front - If you want it on the left then mirror the layout.
The schematic contains the circuit diagram for the breadboard. It is laid out to minimise the number of jumper wires required - many of the connections can be bridged.
An absolute minimum of 4 rows and 29 columns are needed in order to fit the screw holes in. The components are placed as shown:
and from underneath:
As shown on the left of the picture of the underside the encoder's mounting legs have been bent round to hold it securely to the board.
The picture below shows the different circuits.
To start with make the direct connections for "ENC 1", "CONT", "BRT" and "RST".
Next use small lengths of wire to make the remaining connections. Leave as little excess wire as you are comfortable with, as it will be easier to fit into the housing:
Solid lines are wire, dotted lines solder connections.
Now do the LCD: Solder the 6 way right angle headers onto the LCD pins 1-6 and 11-16. The picture shows shrouded headers but normal right-angle pin headers are fine.
Step 3 - Fit the SDSL and 24 way IDC sockets
Using the cable numbering from the cable picture, you are connecting wires number 13-22 into the SDSL plug. Note the polarity as shown in the pictures. Ensure you leave at least 10 cm of length on the cable past the plug, as this will make wiring the remaining connections easier.
The easiest way to fit IDC connectors without a proper (and expensive) tool is to use a small vice. Ensure the cable is in square in the connector and the the pressure applied by the vice is even - don’t rush this bit! The back should click into the connector.
The 24 way IDC socket is fitted in the same way; ensure you use pins 1-22 of the socket (a 22 way socket would be even better but hard to find)
Step 4 - Fitting the crimp connectors.
There are three 6-way connectors and a 2 way connector that use crimp terminals. These can be crimped using small needle nose pliers if you don't have a crimping tool. Nophead has an excellent video on how to crimp them.
I found it easiest to identify the wires for each connector from the circuit diagram and the photo below and cut them to length before fitting the pins. Be sure not to make them too short!
The 12V and ground pins on the expansion header are not used by Panelolu but I have left the wires so they can be connected to something else if required. The pieces of wire offcuts in the picture are used to make the connections between the various sockets (as shown in thicker green wires in the schematic near the top of the blog post). Leave these a little longer than the minimum distance to assist with assembly at the end. On some pins you will need to connect two wires to one pin:
Once complete the assembled cable should look like this:
Step 5 - Assemble
It is easiest to first screw on the SDSL socket and the bread board with the LCD in position, then the strain relief and finally bring the two halves together to plug in the 4 connectors. Although the SDSL itself can be fitted once completely assembled it's easier to fit it at this stage ensuring the orientation is correct.
Close it all up, being careful not to trap any wires. The length of socket setscrews used will depend on the mounting solution. There is a 5th small screw to hold the bottom of the case below the click encoder closed.
To come: I will do a second post about mounting once I have some better pictures of it mounted on a prusa and my Mendel90 mounting solution sorted.
Connecting it to your board
Sanguinololu and Melzi
Just plug it into the header pins on the Sanguinololu board, checking it's the right way around. There are no spare pins on the Sanguinololu to connect a buzzer to.
Melzi: The Melzi is very similar to the Sanguinololu. The header pins on the Melzi are pin compatible (PLEASE CHECK!) with Sanguinololu, except there is no 12V and Ground on the first two pins. Also, because Melzi has an onboard SD Card reader, you will have to do the same changes to the firmware as for the Printrboard.
RAMPS
Taken from http://blog.think3dprint3d.com/2012/11/panelolu-on-ramps-and-printrboard-issues.html
RAMPS provides lots more pins for input/output than Sanguinololu, but they are spread out around the board. You won't be able to use the 24-way IDC connector, and there are no pins on the board for 12V to be passed through, so the first two wires on the ribbon connector are unused and can be taken off, to leave a 20-wire ribbon cable. You'll have to trace each wire to it's respective pin, but by referring to the following diagram and tables, you should be able to connect it up. Just take your time, it worked first try for me!
While the Panelolu kit doesn't integrate a buzzer, RAMPS can support one by using one of the spare pins. There are spare wires on the ribbon cable that can be utilised, and a small enough buzzer might be accommodated inside the standard housing. Connect the positive side of the buzzer to a pin (eg D33), and the negative side to one of the grounds.
Using this diagram for reference, connect the wires to the AUX-3/SPI and AUX-4 connectors on the RAMPS board (this is for RAMPS 1.3; 1.4 has the same pin-out, not sure about 1.2 and earlier):
This table shows the pins that the ribbon cable connects to on the Sanguinololu, and the equivalent on RAMPS:
Ribbon Cable number Function Pin Sanguinololu Pin RAMPS
1 GND GND NA
2 12V 12V NA
3 LCD 1 (VSS - Ground)
LCD 5 (RW - Read/Write)
LCD 16 (K - Backlight Anode-)
Breadboard GND for encoder, switch, contrast, reset.
GND GND (AUX-4)
(or GND on the I2C connector)
4 LCD 2 (VDD 3.3 to 5v)
5V on breadboard, for brightness
5V 5V (AUX-4)
(or 5V on the I2C connector)
5 LCD 14 (DB7 - data bit) A4 D29 (AUX-4)
6 LCD 4 (RS - register select) PWM D12 D16 (AUX-4)
7 LCD 13 (DB6 - data bit) A3 D27 (AUX-4)
8 Encoder1 TX1 D11 D35 (AUX-4)
9 LCD 12 (DB5 - data bit) A2 D25 (AUX-4)
10 Encoder2 RX1 D10 D37 (AUX-4)
11 LCD 11 (DB4 - data bit) A1 D23 (AUX-4)
12 LCD 6 (E - clock) SDA D17 D17 (AUX-4)
13 SD (CS pin) A0 D53 (AUX-3)
14 (via SDSL plug, NC) Encoder click SCL D16 D31 (AUX-4)
15 (via SDSL plug, NC, could be buzzer+ in RAMPS) (D33 (AUX-4) if fitting buzzer)
16 (via SDSL plug, NC)
17 SD Ground GND GND (AUX-3)
18 (via SDSL plug, NC) Reset RST D39, D41, D43, D45, D47 or D32 on AUX-4
or D49 on AUX-3
19 SD (DI pin) MOSI MOSI D51 (AUX-3)
20 SD (SCK pin) SCK SCK D52 (AUX-3)
21 SD 5V 5V 5V (AUX-3)
22 SD (DO pin) MISO MISO D50 (AUX-3)
23 NA NA
24 NA NA
Other LCD 3 (VO - contrast adjuster) to C on breadboard
Other LCD 15 (A - Backlight Anode ) to B on breadboard (brightness)
Here is the above, sorted for each connector on RAMPS:
AUX-4
6 LCD 4 RS (register select) PWM D12 D16
12 LCD 6 E (clock) SDA D17 D17
11 LCD 11 DB4 A1 D23
9 LCD 12 DB5 A2 D25
7 LCD 13 DB6 A3 D27
5 LCD 14 DB7 A4 D29
14 SD, encoder click SCL D16 D31
(Piezo Buzzer ) D33
3 Ground GND GND
4 5V 5V 5V
AUX-3 / SPI
NC NC
21 SD 5V 5V 5V
NC D49
Printrboard
Taken from http://blog.think3dprint3d.com/2012/07/panelolu-with-printrboard.html
The Printrboard is a based on the Teensylu which is itself a derivative of the Sanguinololu; the main difference is the use of the AT90USB1286 in place of the ATmega644P or 1284P.
Thanks to the work of Lincomatic, Marlin firmware will run on the AT90USB1286. The Printrboard section of the RepRap wiki page has information on the board and an outline of how to upload the firmware - you will need Lincomatic's fork of Marlin. The Printrboard I bought was supposed to come with a bootloader but that did not work. I followed Lincomatic's instructions to install the CDC bootloader using the Pololu ISP I have used previously on ATmega644P and ATmega1284P micros. It's worth ensuring you have a working setup with the Printrboard connecting to your control software (Pronterface for me) and firmware uploading before you go any further.
Built in SD card reader or SDSL?
The Printrboard has a build in SD card reader so you do not need an SDSL. That said I prefer to have the electronics hidden away, so using the SDSL in the Panelolu is my preference. Both options will work and are described below.
Hardware and wiring the Panelolu
The wiring internal to the Panelolu is identical to that described above, with the option not to bother with wires 13,15,16,17,19,20,21,22 and the 10 pin IDC connector if you are going to use the build in SD card reader on the Printrboard. Unfortunately the design of the expansion headers on the Printrboard does not keep to the standard 2.54mm spacing between the expansion header and the ISP header (and 4 pins on ext1 are not I/O by default) - a simple IDC connector will not fit without bending the pins . The solution is to use the same connectors that are used on the LCD and circuit board within the Panelolu.
The pin out is as follows:
Ribbon cable wire number Printrboard Pin Label Marlin Pin
number Marlin Pin
name
1 Not used ¹ --- ---
2 Not used ¹ --- ---
3 GND --- ---
4 5V --- ---
5 PD4 4 LCD_PINS_D7
6 A3 41 LCD_PINS_RS
7 PD6 6 LCD_PINS_D6
8 TX1 2 ENC1
9 PE1 9 LCD_PINS_D5
10 RX1 3 ENC2
11 PC1 11 LCD_PINS_D4
12 SDA 1 LCD_PINS_ENABLE
13 A2 ³ 40 SDSS
14 SCL 0
18 RESET ² --- ---
¹ Wire 1 and 2 are not connected/used but kept in for consistency with the original instructions.
² Can come either from the RESET pin on the expansion header or the ISP header.
³ Only required if a SDSL is used rather than the on board SD card reader
Update: There was a mistake in the table above, thanks to Colin Bradburne for bringing the problem to my attention. It is fixed now - the lines in red have been amended. (See original blog)
If using the SDSL rather than the on board SD card reader then the following connections to the ISP header are used as well.
Ribbon cable wire number Printrboard Pin Label Marlin Pin number Marlin Pin name
17 GND --- ---
18 RESET --- ---
19 MOSI 22 MOSI_PIN
20 SCLK 21 SCK_PIN
21 5V --- ---
22 MISO 23 MISO_PIN
The Printrboard I bought does not have the expansion header pins labeled, I have annotated the pins on the screen shot of the board below:
The 4 pins labeled "JTAG PINS" are set to the JTAG interface by default - I have done a separate blog post about how to change the fuse settings to gain access to these pins as I/O. This does mean that we can't fit the Panelolu connections onto just one expansion header, hence the 4 pins on the second expansion header towards the centre of the board.
The ribbon cable with the connectors will look like this:
Pairing this picture with the annotated screen shot of the board should show how to plug in the cables. (note that wire 1 and 2 are not in this picture as they are not used and that a 4 pin connector is used for MISO,SCLK and RESET because I ran out of 3 pin connectors)
Firmware
Depending on the version of Marlin you have, line numbers may be different. However, the following lines should be nearby somewhere!
Sanguinololu
In order to use this you need a 1284P in your Sanguinololu and the Marlin firmware needs the changes that I mentioned in my previous post and have pasted here as well:
In Configuration.h:
Line 34:
 #define MOTHERBOARD 62
Line 190-205:
 #define EEPROM_SETTINGS
   //to disable EEPROM Serial.....
   // please keep turned on if you can.
 #define EEPROM_CHITCHAT
 #define ULTIPANEL
 #ifdef ULTIPANEL
   #define NEWPANEL  //enable this if you have a clicencoder panel
   #define SDSUPPORT
   #define ULTRA_LCD
   #define LCD_WIDTH 20
   #define LCD_HEIGHT 4
In Configuration_adv.h:
Line 163:
 //#define SDCARDDETECTINVERTED
In pins.h:
making sure to be within the sanguinololu pin definition part of the file. For my pins.h this was lines 557 - 657. I added the following 34 lines, copied from the RAMPS section of the pins.h
 #ifdef ULTRA_LCD
   #ifdef NEWPANEL
     //we have no buzzer installed
     #define BEEPER -1
     //LCD Pins
     #define LCD_PINS_RS        4
     #define LCD_PINS_ENABLE    17
     #define LCD_PINS_D4        30
     #define LCD_PINS_D5        29
     #define LCD_PINS_D6        28
     #define LCD_PINS_D7        27
     //The encoder and click button
     #define BTN_EN1 11  //must be a hardware interrupt pin
     #define BTN_EN2 10 //must be hardware interrupt pin
     #define BTN_ENC 16  //the switch
     //not connected to a pin
     #define SDCARDDETECT -1
     //from the same bit in the RAMPS Newpanel define
     //encoder rotation values
     #define encrot0 0
     #define encrot1 2
     #define encrot2 3
     #define encrot3 1
     #define BLEN_C 2
     #define BLEN_B 1
     #define BLEN_A 0
   #endif //Newpanel
 #endif //Ultipanel
RAMPS
In Configuration.h:
Line 34:
 #define MOTHERBOARD 33
Line 190-205:
 #define ULTIPANEL
 #ifdef ULTIPANEL
   #define SDSUPPORT
   #define ULTRA_LCD
Line 163:
In pins.h, making sure to be within the RAMPS pin definition part of the file. For my pins.h this was lines 315 - 533. The following is already in the RAMPS definition - changes in bold, comments in red:
 #ifdef ULTRA_LCD
   #ifdef NEWPANEL
     #define BEEPER 33 If you DO have a buzzer installed
     //For reset switch
     #define KILL_PIN 39 Set to the number of the pin you actually use, if not D39
     //LCD Pins
     #define encrot0 0
     #define encrot1 2
     #define encrot2 3
     #define encrot3 1
     #define BLEN_C 2
     #define BLEN_B 1
     #define BLEN_A 0
   #endif //Newpanel
 #endif //Ultipanel
Printrboard
The following firmware changes to Marlin are required to get the Panelolu working with a Printrboard. Please note that line numbers are based on my version of Lincomatic's branch of Marlin - they may be slightly different with a different version or after additional changes are made.
Configuration.h
line 34-40:
 #define MOTHERBOARD 81
 #if (MOTHERBOARD == 81) //printrboard
   #define SDSUPPORT
   //comment out the following line to use onboard SD card reader
 #define USESDSL
 #endif
line 234:
 #define ULTIMAKERCONTROLLER
Pins.h
within the Printrboard (81) section
line 953 -984:
 #ifdef ULTRA_LCD
   #ifdef NEWPANEL
     #define BEEPER -1
     //LCD Pins
     #define LCD_PINS_RS        41
     #define LCD_PINS_D4        11
     #define LCD_PINS_D5        9
     #define LCD_PINS_D6        6
     #define LCD_PINS_D7        4
     #define BTN_EN1 2  //must be a hardware interrupt pin
     #define BTN_EN2 3 //must be hardware interrupt pin
     #define BTN_ENC 0  //the click
     //not connected to a pin currently
     #define encrot0 0
     #define encrot1 2
     #define encrot2 3
     #define encrot3 1
     #define BLEN_C 2
     #define BLEN_B 1
     #define BLEN_A 0
   #endif //Newpanel
 #endif //Ultipanel
Sd2PinMap.h
Line 224-236
 // SPI port
 #if MOTHERBOARD == 81 //printrboard
 #ifdef USESDSL  //SDSL with Panelolu
 uint8_t const SS_PIN = 40;    //F2
 #else
 uint8_t const SS_PIN = 26;    // B6
 #endif
 #else
 uint8_t const SS_PIN = 20;    // B0
 #endif
 uint8_t const MOSI_PIN = 22;  // B2
 uint8_t const MISO_PIN = 23;  // B3
 uint8_t const SCK_PIN = 21;   // B1</code>
To explain what the firmware changes actually do:
  • Add the USESDSL define to configuration.h which allows easy toggling between the onboard SD card reader and the SDSL
  • Enable the ULTIMAKERCONTROLLER which the PanelMax and Panelolu are derivatives of.
  • Define the pins that are used for the Panelolu within the Printrboard section of the pins definition file
  • Add a check to the SdPinMap to see if SDSL on onboard card reader is selected with the USESDSL define.
