Plastic T-slot
Revision as of 18:18, 21 July 2011 by Luke (talk | contribs)
Plastic T-slot
Release status: Experimental
Plastic T-slot is a construction platform that can be printed or professionally extruded
A plastic T-slot beam and accessory line is being developed as the main construction method for a 3D Printer as well as a competent prototyping and hobby construction set. It is developed with these considerations in mind to give it advantage over other methods:
  • Designed to be printed at home and fused into beams of any length
  • Designed in conjunction with professional plastic die extrusion so that structurally solid and dimensionally stable beams may be quickly and cheaply produced
  • A fully printable method for joining beams and attaching accessories
  • A beam profile that remains printable when scaled
  • Accessories developed with 3d printing and robotics specifically in mind
