Printcore 3p2.py
#!/usr/bin/env python from serial import Serial from threading import Thread import time import sys class printcore(): def __init__(self,port=None,baud=None): """Initializes a printcore instance. Pass the port and baud rate to connect immediately """ self.baud=None self.port=None self.printer=None #Serial instance connected to the printer, None when disconnected self.clear=0 #clear to send, enabled after responses self.online=False #The printer has responded to the initial command and is active self.printing=False #is a print currently running, true if printing, false if paused self.mainqueue=[] self.priqueue=[] self.queueindex=0 self.lineno=0 self.resendfrom=-1 self.paused=False self.sentlines={} self.log=[] self.sent=[] self.tempcb=None#impl (wholeline) self.recvcb=None#impl (wholeline) self.sendcb=None#impl (wholeline) self.errorcb=None#impl (wholeline) self.startcb=None#impl () self.endcb=None#impl () self.onlinecb=None#impl () self.loud=False#emit sent and received lines to terminal if port is not None and baud is not None: #print port, baud self.connect(port, baud) #print "connected\n" def disconnect(self): """Disconnects from printer and pauses the print """ if(self.printer): self.printer.close() self.printer=None self.online=False self.printing=False def connect(self,port=None,baud=None): """Set port and baudrate if given, then connect to printer """ if(self.printer): self.disconnect() if port is not None: self.port=port if baud is not None: self.baud=baud if self.port is not None and self.baud is not None: self.printer=Serial(self.port,self.baud,timeout=5) Thread(target=self._listen).start() def reset(self): """Reset the printer """ if(self.printer): self.printer.setDTR(1) self.printer.setDTR(0) def _listen(self): """This function acts on messages from the firmware """ self.clear=True time.sleep(0.5) self.send_now("M105") while(True): if(not self.printer or not self.printer.isOpen): break line=self.printer.readline() if(len(line)>1): self.log+=[line] if self.recvcb is not None: try: self.recvcb(line) except: pass if self.loud: print(bytes("RECV: ","ascii")),line.rstrip() if(line.startswith(bytes('DEBUG_',"ascii"))): continue if(line.startswith(bytes('start',"ascii")) or line.startswith(bytes('ok',"ascii"))): self.clear=True if(line.startswith(bytes('start',"ascii")) or line.startswith(bytes('ok',"ascii")) or bytes("T:","ascii") in line): if (not self.online or line.startswith(bytes('start',"ascii"))) and self.onlinecb is not None: try: self.onlinecb() except: pass self.online=True if(line.startswith(bytes('ok',"ascii"))): #self.resendfrom=-1 #put temp handling here if bytes("T:","ascii") in line and self.tempcb is not None: try: self.tempcb(line) except: pass #callback for temp, status, whatever elif(line.startswith(bytes('Error',"ascii"))): if self.errorcb is not None: try: self.errorcb(line) except: pass #callback for errors pass if bytes("resend","ascii") in line.lower() or bytes("rs","ascii") in line: try: toresend=int(line.replace("N:"," ").replace("N"," ").replace(":"," ").split()[-1]) except: if "rs" in line: toresend=int(line.split()[1]) self.resendfrom=toresend self.clear=True self.clear=True #callback for disconnect def _checksum(self,command): return reduce(lambda x,y:x^y, map(ord,command)) def startprint(self,data): """Start a print, data is an array of gcode commands. returns True on success, False if already printing. The print queue will be replaced with the contents of the data array, the next line will be set to 0 and the firmware notified. Printing will then start in a parallel thread. """ if(self.printing or not self.online or not self.printer): return False self.printing=True self.mainqueue=[]+data self.lineno=0 self.queueindex=0 self.resendfrom=-1 self._send("M110",-1, True) if len(data)==0: return True self.clear=False Thread(target=self._print).start() return True def pause(self): """Pauses the print, saving the current position. """ self.paused=True self.printing=False time.sleep(1) def resume(self): """Resumes a paused print. """ self.paused=False self.printing=True Thread(target=self._print).start() def send(self,command): """Adds a command to the checksummed main command queue if printing, or sends the command immediately if not printing """ if(self.printing): self.mainqueue+=[command] else: while not self.clear: time.sleep(0.001) self._send(command,self.lineno,True) self.lineno+=1 def send_now(self,command): """Sends a command to the printer ahead of the command queue, without a checksum """ if(self.printing): self.priqueue+=[command] else: while not self.clear: time.sleep(0.001) self._send(command) #callback for command sent def _print(self): #callback for printing started if self.startcb is not None: try: self.startcb() except: pass while(self.printing and self.printer and self.online): self._sendnext() if self.endcb is not None: try: self.endcb() except: pass #callback for printing done def _sendnext(self): if(not self.printer): return while not self.clear: time.sleep(0.001) self.clear=False if not (self.printing and self.printer and self.online): self.clear=True return if(self.resendfrom<self.lineno and self.resendfrom>-1): self._send(self.sentlines[self.resendfrom],self.resendfrom,False) self.resendfrom+=1 return self.resendfrom=-1 for i in self.priqueue[:]: self._send(i) del(self.priqueue[0]) return if(self.printing and self.queueindex<len(self.mainqueue)): tline=self.mainqueue[self.queueindex] tline=tline.split(";")[0] if(len(tline)>0): self._send(tline,self.lineno,True) self.lineno+=1 else: self.clear=True self.queueindex+=1 else: self.printing=False self.clear=True if(not self.paused): self.queueindex=0 self.lineno=0 self._send("M110",-1, True) def _send(self, command, lineno=0, calcchecksum=False): if(calcchecksum): prefix="N"+str(lineno)+" "+command command=prefix+"*"+str(self._checksum(prefix)) if("M110" not in command): self.sentlines[lineno]=command if(self.printer): self.sent+=[command] if self.loud: print("SENT: "),bytes(command,"ascii") if self.sendcb is not None: try: self.sendcb(bytes(command,"ascii")) except: pass # print(command) self.printer.write(bytes(command,"ascii")+bytes("\n","ascii"))
if __name__ == '__main__': #print "Usage: python printcore.py filename.gcode" #filename="../prusamendel/sellsx_export.gcode" #if len(sys.argv)>1: # filename=sys.argv[1] # print "Printing: "+filename #else: # print "Usage: python printcore.py filename.gcode" #sys.exit(2) p=printcore('/dev/ttyACM0',115200) p.loud=False statusreport=False time.sleep(2) print(p.printer) #testdata=[i.replace("\n","") for i in open(filename)] #p.startprint(testdata) #time.sleep(1) #p.pause() #print "pause" #time.sleep(5) #p.resume() #try: #if statusreport: # p.loud=False # sys.stdout.write("Progress: 00.0%") # sys.stdout.flush() # while(p.printing): # time.sleep(1) # if statusreport: # sys.stdout.write("\b\b\b\b%02.1f%%" % (100*float(p.queueindex)/len(p.mainqueue),) ) # sys.stdout.flush() #except: wait = 0 while (not p.online or wait > 100): time.sleep(1) wait += 1 print( str(wait) + "\n") if p.online: p.printer.write(bytes("G1 X5\n","ascii")) # print("move X") time.sleep(2) p.printer.write(bytes("G1 Y5\n","ascii")) time.sleep(2) # print ("move Y") p.printer.write(bytes("G1 Z5\n","ascii")) time.sleep(2) # print ("move Z") p.disconnect()
