RP9
RP9
Release status: prototype
Description | Simple cost effective RepStrap
License | unknown
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Overview
This RepStrap is an attempt to create a simple cost effective design. The objective is to create a kit that has all the hardware needed for xyz motion. Steppers, electronics , and an extruder can be added to complete the printer
Design Objectives
- 5 ply 6 mm plywood construction
- 8 mm steel for linerar motion
- 8 mm LM8UU bearings
- 200 mm x 200 mm x 200 mm build area
- Spectra fishing line drive
- Fabricate mechanical hardware in less than 2 hours
- Completely Open Source
- Minimal part count
Current Status
Progress will be slow due to the need for employment. The development of a router/mill CNC files is in progress. File:Emount.jpg
Current Part List
Current part list for build kit | |||||
Part Name | Description | Procurement Type | Quantity | ||
Side frame | 6 mm 5 ply plywood | Make | 2 | ||
Top brace | 6 mm 5 ply plywood | Make | 2 | ||
Bottom brace | 6 mm 5 ply plywood | Make | 2 | ||
Table | 6 mm 5 ply plywood | Make | 1 | ||
Top motor mount | 6 mm 5 ply plywood | Make | 2 | ||
Bottom motor mount | 6 mm 5 ply plywood | Make | 1 | ||
Extruder mount | 6 mm 5 ply plywood | Make | 1 | ||
z bearing support | 25.4 mm x 25.4 mm x 66 mm UHMW | Make | 2 | ||
linear rail | 8 mm drill rod 300 mm long | Make | 6 | ||
linear bearing | 8 mm LM8UU | Buy | 8 | ||
Spectra fishing line | for driving x and y axis | Buy | 1 | ||
623VV bearing | bearing for driving y axis | Buy | 1 | ||
M6 threaded insert | for driving z axis | Buy | 2 | ||
M6 threaded rod | for driving z axis | Buy | 2 | ||
Coupler | 5 mm x 6 mm coupler for driving z axis | Buy | 2 | ||
Hardware | To be determined | Buy | + | ||
Total | 35+ |
