RUG/Pennsylvania/State College/Linux
Installing Software
Before installing anything remove "britty"
sudo apt-get remove brltty
Start with Slic3r
sudo apt-get install git build-essential libgtk2.0-dev libwxgtk2.8-dev libwx-perl libmodule-build-perl libnet-dbus-perl sudo apt-get install libwx-perl sudo apt-get install cpanminus sudo cpanm Boost::Geometry::Utils Math::Clipper \ Math::ConvexHull Math::ConvexHull::MonotoneChain Math::Geometry::Voronoi Math::PlanePath Moo Wx
If you have trouble getting cpanminus try:
sudo apt-get install curl curl -L http://cpanmin.us | perl - --sudo App::cpanminus sudo git clone https://github.com/alexrj/Slic3r.git
ReplicatorG
sudo apt-get install openjdk-6-jdk python python-tk python-psyco sudo add-apt-repository "deb http://archive.canonical.com/ubuntu natty partner" sudo apt-get update sudo apt-get install sun-java6-jre
If java does load run:
sudo update-alternatives --config java
and pick "/usr/lib/jvm/java-6-sun/jre/bin/java" it should be the last one in the list. Printrun runs for these files
