RUG/Pennsylvania/State College/Presentation
What's New?
9.15.11: The new units are coming along nicely, check out the current photos below!
8.22.11: The Spring Semester began this year with a new set of students for EDSGN 497C. Along with students from last year's "Alpha" class, the new "Beta" students are making quick work of 4 new Ohm models.
7.8.11: FabLab class at PSU (EDSGN 497C) has a few openings, but anyone having trouble should email the professor [email protected] Audits are more than welcome as well.
6.1.11: Summer FabLab development in full swing printing parts for four printers to be built in class this fall.
4.28.11: Showcased RepRap Mendels at the Penn State Senior Design Fair!
10.11.11: The fall semester is in full gear and repraps are being quickly made! These two photos are from the blue team or the "clear mendel" team - MReng
Local Prototyping Systems
Projects
Lever Switch Endstops | How to hook up lever switches to replace optical endstops |
Tip Profiles | Description of tips built by the class. |
TechZone InfoHub | Collection of links for info on TechZone part builds. |
Waste Reclamation System | Discussion on recycling print material. |
3D Scanner Projects | Info page for 3D scanner in 305 Hammond. |
Imperial Reprap SAE | Discussion on using imperial parts instead of metric. |
Heated Bed | Discussion on a design for a heated bed. |
Electronics | Outline and discussion on alternate electronics. |
Z Opto Holder | A design for a holder for the Z-opto. STL files posted. |
Pen Plotter | A design for a universal pen holder. STL files posted. |
CAD files | Posting Page for CAD files |
OHM | Open Hybrid Mendel |
Useful Links
- Gcode for RepRaps
- Good guide to Skeinforge
- Skeinforge PLA Profile
- Gen6 SF Settings
- All About Patents
- Plugins for Sketchup file to export .stl
- AccuTrans3D (trial version) stl file editor and save
- Tips for Printing with RepSnapper
- Teacup Firmware
- Pen Plotting
- DIY PCBs toner transfer method
Firmware and Files
File:EMFApr29profiles.rar | Skeinforge Profiles |
File:EMFApr29alterations.rar | Skeinforge Alterations |
File:Fix.rar | AWK Script for fixing Skeinforge |
File:EMFapr29awk.rar | Happy Vally AWK Directory |
File:FirmwareforOneWireAD heatbed brnrd 20110317.zip | documented here |
File:Emf Bestextruder4 07.rar | A copy of the extruder code we have been using with max endstops enabled. |
File:Psu Bestmobocode2 24 2011.rar | TZ Gen3 Mobo code altered for our machines |
File:Extruder class jpj12 2011-04-07 temp fix.pde | Modified version of Bestextruder4_07 with brnrd's fix for temp overflow bug. DOES NOT WORK |
File:SC Skeinforge Mar24.rar | Skeinforge Settings as of March 24 |
Subpages
<splist/>
Members
Copy and edit the following from "Example User" to your own handle to add yourself to the membership list:
- Nix-7c0
- joshj
- bjs5286
- EtherDais
- PhiloXXI
- KtripPSU
- php5014
- mslusher2011
- KtripPSU
- Jza127
- Dpd5061
- Nathanb
- Dak
- Jgb5067
- ama5229
- arfalcsik
- marcierengifo
