RUG/Pennsylvania/State College/Printers/BioFab@Home
Revision as of 13:25, 24 June 2014 by Heisenberg Jones (talk | contribs)
Introduction
This is the page for the State College Rep Rap User Group's (SCRUG) Fab@Home 3D printer that is being converted to print a variety of biological materials. The printer was originally constructed in accordance to the original Fab@Home Model 1 design, incorporating the original electronics and single-syringe tip extruder. The build progress was documented here.
Log
Date | Modification / Problem |
6/13/2014 | Up and running very smoothly! Double linear bearings on Y fixed slop on the axis. |
6/9/2014 | Tested with linear bearings on all axes. Good movement, but needs double bearings on Y for proper stability. |
04/22/2014 | Extruder tested and working. Can both extrude and retract water |
03/24/14 | Successful conversion to RAMPS 1.4 electronics with 1/8 step settings and 300 mm/sec speeds. |
02/24/14 | Beginning conversion to RAMPS 1.4 |
