RUG/Pennsylvania/State College/Printers/PSU Unit Mondo
On this page you will find the current status of the Unit M Mondo. Our Mendel Unit is a Techzone laser-cut Mondo. So far, no major design components have been changed from what you get from Techzone. Eventually the plan is to use this large unit with a dual extruder. Much more information can be found at RUG/Pennsylvania/State_College/Dual_Extruder
We are having trouble getting the Techzone thermocouple and tip board working with Ramps. Currently we are using an additional thermistor attached to the hot tip, but this is causing a lower temperature to be read by the board.
Operating Specifications
Operating Specifications | |||||||
Name | Status | Design | Electronics | Firmware | Extruder | Temperature | Comments |
Mondo | NOT ASSEMBLED | TechZoneMondo | Ramps V1.4 | Marlin | ??? | ??? | Currently under construction |
Build Status
What has been done: Frame assembly, Electronics installation
What needs to be done: Get Thermistor working, Pronterface won't allow for what it thinks is cold extrusion, but the placement of the thermistor reads a lower than actual temperature.
