RUG/Pennsylvania/State College/Printers/PSU Unit Purple
This page is for information about the PSU Unit Purple, which is assembled and undergoing testing. This unit will follow the design of the Ohm. All of the printable parts are printed in PLA and assembled. The purple printer was constructed by Matt R, Deanna M, Bill F, and Yaqi Y.
CURRENT STATUS: The printer is fully assembled, however filament feed issues need to be addressed. The filament hole in the extruder body needs aligned with the metal plate and hot tip. Disassembly of the extruder will be necessary.
Operating Specifications
Operating Specifications | |||||||
Name | Status | Design | Electronics | Firmware | Extruder | Temperature | Comments |
Purple | Assembled | Ohm | Ramps V1.4 | Marlin | Joe/Kevin/Wade/Greg extruder 0.35mm hot tip | ??? | Assembled. The extruder body and hot plate/hot tip are not lined up perfectly, preventing PLA feeding into the extruder. Use Slic3r settings for .35mm tip. |
Pictures
Builders
Build Team |
Bill Fabrizi |
Deanna Moschitta |
Matt Rockar |
YaqiYang |
