RapManFirmwareDevelopment
Building the RapMan firmware might require a Microsoft Windows based setup. The following is tested in a Windows XP running through VirtualBox on Kubuntu.
Download MPLAB from here or zip
Install it. You don't need to install the HI TECH C.
Download tortoise SVN (32 bit), other/newer versions or anther tool that allows you to access the recent code from the repository.
Check out this repository https://reprap.svn.sourceforge.net/../users/erik/OpenRapMan/EriksBranch/bfb-firmware-dev3. You can do this by creating a folder from windows explorer and right-clicking "Check out a repository". Put the aforementioned URL in the box and proceed with checking it out.
Open the "bfb-firmware-dev.mcp" MPLAB Project file.
Use: "Build all" to build the file. You can flash the firmware using the HIDBootLoader.exe included in the same folder. Browse to find the .hex file that has a recent modification timestamp. If the .hex file is older, something has gone wrong with your compilation process!
It should compile. If it doesn't, check the includes: Projects -> Build Options... -> Project. Go to the tab "Directories". Choose: show directories for "Include search path". Check if these are indeed the path where these files can be found. "MPLAB C32" is not the same as "MPLAB C32 [bSuite[/b]". Microchip Inc. has changed the default installation paths apparently.
If you have changes, send them to [email protected] for inclusion in this openRapMan branch.
-- Erik de Bruijn
