RepRap Samuel
Revision as of 05:38, 6 October 2014 by Silpstream (talk | contribs) (Introduction)
Samuel
Silpstream's Augmented Mendel a.k.a Samuel
Introduction
RepRap Samuel is designed to reuse the vitamins and some parts from the Prusa Mendel i2 or the Mendel. As such, an owner of either of the RepRaps should be able to print the new parts on their existing 3D printer to rebuild it into Samuel. It's design objectives are:
  • Reuse vitamins and parts from RepRap Mendel
  • Increase build volume in the Z-axis
  • Improve X-motion stability
  • Upgrade X-axis to newer vertical designs
Specification
  • Size: 420x420x440mm
  • Build Volume: 196m x 196 mm x 200mm
  • 5 x NEMA 17 motors
  • Electronics: Should work with most RepRap electronics
  • Structural materials: M8 rods, ABS/PLA
Parts
You can find all files on reprap_samuel@GitHub.
Picture Part Comment
Sam 20deg-sup.jpg sam_20deg-sup-L.stl
sam_20deg-sup-R.stl
Sam 20deg-vertex.jpg sam_20deg-vertex-L.stl
sam_20deg-vertex-R.stl
Sam 60deg-vertex.jpg third_party/prusa-leveling-vertex-M8-M4.stl
Sam vertex.jpg sam_vertex-L.stl
sam_vertex-R.stl
Sam crossbar-sup.jpg sam_crossbar-sup-L.stl
sam_crossbar-sup-R.stl
Sam z-axis-top-sup.jpg sam_z-axis-top-sup-L.stl
sam_z-axis-top-sup-R.stl
Sam-3 frame-stabilizer-m.jpg third_party/Stabilizer_M_2sides.stl
Sam z-motor-mount-top.jpg sam_z-motor-mount-top-L.stl
sam_z-motor-mount-top-R.stl
Sam z-motor-mount.jpg sam_z-motor-mount-btm-L.stl
sam_z-motor-mount-btm-R.stl
Sam leveling-foot.jpg sam_leveling-foot.stl
Sam direct-drive-lever.jpg sam_direct-drive-parts.stl
Sam direct-drive-spring-holder.jpg sam_direct-drive-parts.stl
Sam extruder-jhead-base.jpg sam_extruder-jhead-base.stl
Sam extruder-jhead-clamp.jpg sam_extruder-jhead-clamp.stl
Sam x-carriage.jpg sam_x-carriage.stl
Sam x-belt-clip.jpg sam_x-belt-clip.stl
Sam fan-arm.jpg sam_fan-arm.stl
Sam fan-mount.jpg sam_fan-mount.stl
Sam-3 fanduct-supportless v2.jpg third_party/FanDuct-Supportless_v2.stl
Sam x-end-clamps.jpg sam_x-end-clamps.stl
Sam x-end-idler.jpg sam_x-end-idler.stl
Sam x-end-motor.jpg sam_x-end-motor.stl
Sam x-end-pulley-spacer.jpg sam_x-end-pulley-spacer.stl
Sam x-end-pulley.jpg sam_x-end-pulley.stl
Sam x-end-rod-spacer.jpg sam_x-end-rod-spacer.stl
Sam x-end-tensioner.jpg sam_x-end-tensioner.stl
Sam-3 unbreakable-bar-clamp.jpg third_party/bar-clamp_pinchclamp3.stl
Sam y-bed-support.jpg sam_y-bed-support-L.stl
sam_y-bed-support-R.stl
Sam-3 bed-levelling-thumb-wheel.jpg third_party/Thumb_wheel_slim.stl
Sam y-lm8uu-no-spring.jpg sam_y-lm8uu-no-spring.stl
Sam y-lm8uu-nut-retainer.jpg sam_y-lm8uu-nut-retainer.stl
Sam y-lm8uu-spring.jpg sam_y-lm8uu-spring.stl
Sam t25-belt-clamp-block.jpg sam_t25-belt-clamp-parts.stl
Sam t25-belt-clamp-cap.jpg sam_t25-belt-clamp-parts.stl
Sam t25-belt-clamp-nipple.jpg sam_t25-belt-clamp-parts.stl
Sam t25-belt-clamp-nut-retainer.jpg sam_t25-belt-clamp-parts.stl
Sam t25-belt-clamp-rib.jpg sam_t25-belt-clamp-parts.stl
Sam y-motor-mount.jpg sam_y-motor-L.stl
sam_y-motor-R.stl
sam_y-motor-pulley-spacer-sml.stl
Build
Detailed pictures to show how the parts go together.
