RobunDel
Revision as of 15:27, 20 June 2011 by ROTORIT (talk | contribs)
RobunDel
RobundDel Is a Mendel (like) printer only slightly bigger and more robust than a Standard one.
GPL
RobundDel Is a Mendel (like) printer only slightly bigger and more robust than a Standard one. All the threaded/smooth rods is 500mm long and the intention was to make the most use of the length of them in favor to gain a bigger build area without compromising on print speed and quality. It have 2 Nema 17 stepper motors on all axes to reduce the risk of missing steps.
It is working but still in development and will be edited in the near future.
I have my RobunDel inside a box with ventilation.
Lower frame corner vertex is made to fit 8mm threaded rods for the lower frame and 16mm rods for the upper frame.
Stl file for Vertex Lower
The Y motor brackets is also feet's to increase stability in the lower frame at the rods is as long as 500mm.
There is 2 of these as there is 2 stepper motors in the y axis.
STL file for Y Motor Bracket
X end motor bracket is not attached to the z bearing system.
STL for the X end motor bracket
Y axis bearing system is now LM8UU liniear bearings with bearing holder designed by Jolijar thingiverse.com/thing:7755 . I will test this for a while and see if it is good enough to implement permanently.
STL for the Y Bearing Holder
Z axis bearing system is standard Mendel Sells (for now.. will change)
X axsis bearing system is a Derivative from thingiverse.com/thing:6641 (for now and will probably change)
Top vertex is a derivative of Tersla893`s Mixtape Mendel reprap.org/wiki/Mixtape_mendel (for now..will change)
