Shiva Hot-End/es
Revision as of 13:40, 13 May 2013 by DavidCary (talk | contribs) (moved Shiva Hot-End to Shiva Hot-End/es: consistency -- perhaps foolish consistency.)
Language Issue/s on this page!
This article needs translation into English.
This article is written in a language other than English. As it is intended for readers from the RepRap community, Alternate translations are encouraged. In particular, an English translation is required. Please see the layout and translations of the http://www.reprap.org/wiki/Main_Page as an example of how this should be achieved. in short you should follow these conventions: If your page is called XXXXX, and is not in english, please do the following:
  • add a languages header to the page, using {{Languages}}
  • copy the non-english content from the "primary" page to the appropriate language page. For example, if your content is in Deutsch, move the content from XXXXX to XXXXX/de
  • revise the original XXXXX page to be english-only, except for the "Languages" header.
Shiva Hot-End
Release status: Experimental
Hot-End
Experimental (!)
Introduction
The Clone Wars project is a project started by people from the Carlos III University of Madrid (Spain) with the goal of promoting the making of RepRaps ("clones") around Spain. Over the time it has become the main hub for the Spanish community.
At this point this is highly experimental, so use at your own risk.
Dentro de este proyecto , también esta el de desarrollar hotends propios, de forma que no se dependa del exterior. Otros usuarios del grupo también están realizando un trabajo similar (AREN3D con SPbudas, Carlos CADesigns , CAPI son de los que tengo noticias) , pero su inspiración es en el Budas.
Shiva Hot-End v0.1
Inspirado en el Parcan v1,también conocido comúnmente como Hotend ReprapWorld v5 Prueba única del nozzle y del aislante a través de corcho natural. Sujeción externa a través una placa que sostiene al nozzle
  • Esquema
En construcción.Próximamente!
  • BOM
    • En construcción.Próximamente!
  • Proceso de fabricación
    • Cortar la varilla de latón
    • Fresar la forma de la boquilla
    • Fresar muesca para la resistencia y el thermisthor
    • Corte de las chapas
    • Taladrado de las chapas
    • Montaje
  • Fotos del montaje
  • Fotos de las pruebas
Conclusiones:
-El reflujo es excesivo, de hecho es igual que en el Parcan v1 tras varias horas de impresión -El calor transportado por la sujeción es excesivo, debido que sea completamente de metal. Habría que añadir aislante y esto aumentaría el coste. - El corcho natural se quema y además , al taladrarlo no queda liso, por lo que dificulta la extrusión. Material descartado.
Comparativa Parcanv1 vs J-Head MK-IV
Debido a que los fallos eran similares al Parcan v1, decidí comprar y probar un J-Head MK-IV. Estas son mis conclusiones:
Ventajas del J-Head sobre el Parcan v1
-Sin reflujo: Creo que la causa es debida a que la rosca del nozzle es interior y no exterior como en Parcan v1 -Sin sujeccion externa. Se traduce en simplicidad de montaje y menos materiales
Ventajas del Parcan v1 sobre el J-Head
-Precio -Simplicidad de fabricación
Conclusión: Lo mejor es intentar realizar una version del J-Head más simple y barato, ya que es mejor diseño.
Shiva Hot-End v0.2
En esta versión se deja de un lado la orientación hacia el Parcan v1 para pasar al J-Head MK-V No se va a llevar a cabo la utilización de un ventilador de refrigeración, ya que se desea un hotend lo más sencillo posible. Esta versión se utiliza unicamente para comprobar el reflujo en la unión del aislante con el nozzle y la temperatura superior.
  • Mejoras con respecto a la version anterior
-Sujeccion directa -Cambiamos el tubo contenedor de la resistencia por un bloque. -Añadimos unas tuercas M8 estandar y unas arandelas estandars para que actuen como aletas.
  • Esquema
  • BOM
-Cortar la varilla roscada de latón -Fresar la forma de la boquilla -Fresar muesca para la resistencia y el thermisthor -Corte de la chapa -Taladrado de la chapa -Fresado del tubo de PTFE -Roscado del tubo de PTFE -Montaje
  • Fotos del montaje
Conclusiones:
-El calor transportado por el PTFE es excesivo. El flujo de calor debe ser disipado. -No hay reflujo
Shiva Hot-End v0.3
Aumentamos la longitud total del hotends, asi como la del PTFE y cambiamos el tubo contenedor de la resistencia por un bloque.
  • Mejoras
-Aumentamos la superficie de las aletas con unas arandelas anchas -La boquilla de el nozzle es intercambiable -Sitema de presilla para el thermistor, de forma que no pueda salirse y no dependa del kapton.
  • Esquema
  • BOM
-Cortar la varilla roscada de latón -Fresar en la boquilla la muesca para el thermistor -Fresar muesca para la resistencia en el bloque -Roscado del tubo de el bloque -Fresado del tubo de PTFE -Roscado del tubo de PTFE -Montaje
  • Fotos del montaje
Conclusiones:
-Fallo total: desbordamiento en la rosca.
Shiva Hot-End v0.4
(29-12-12) Introducimos un tornillo de fijación para intentar evitar el desbordamiento y hacemos un estudio termico del hotend.
  • Imagenes estudio térmico
Estudio térmico con aletas, sin aletas y con todo el cuerpo recubierto de PTFE
Conclusión:
El tornillo se dilata en la misma propocion que el PTFE que lo sostiene. Sin embargo es la solución que utiliza los hotends de Smdking (¿diferencia?)
Shiva Hot-End v0.5
(01-01-13) Introducimos una abrazadera de fijación. Es el último intento antes de cambiar el cuerpo de PTFE a PEEK.
Shiva Hot-End v0.6 (aka Nirvana)
(30-01-13) Rediseño completo basandose en el North90's v2. Estudio térmico incluido
Conclusion:
Demasiado reflujo. Hay que probar incluyendo un ventilador de 40x40 mm
Shiva Hot-End v0.7
Seguimos con el modelo probado en v0.5. Cambiamos el cuerpo de PTFE a PEEK.
Shiva Hot-End v0.8
Seguimos con el modelo probado en v0.6. Finalmente añadimos el ventilador, que refrigera todo el cuerpo
Links
http://en.wikipedia.org/wiki/Shiva
