Sid
Revision as of 08:58, 7 October 2014 by Simplifi3D (talk | contribs) (Contact)
Sid Documentation
Sid
A printer designed for education. No screws required for structural components
Thingiverse [1], Youmagine [2]
Sid was designed by Prad Lal of Blokko (http://www.blokko.com) and Simplifi3D (http://www.simplifi3d.asia) for education. No screws are required for the assembly of structural components.
Project Goal
Designed as an educational printer kit that even a 9-year old can put together in 2 hrs.
Overview
The linear motion is based on Barton Dring's Makerslide. This printer was designed to be built with no tools by using slots and clips for connecting the various parts.
  • Build volume: 100 (L) x 100 (W) x 100 (H) mm
  • Printer Size (when assembled): 400 (L) x 350 (W) x 290 (H) mm
  • Power input: 110-240V 50-60Hz
  • Nozzle size: 0.4mm
  • Filament diameter: 1.75mm
  • Material: PLA
  • Controller: RAMPS 1.4
  • Firmware: Repetier-Host
Non-printed Parts List
S/N Item description Specifications Quantity Remarks
1 Makerslide 240mm 2 [3] from http://makerslide.com/
2 Makerslide 250mm 2 [4] from http://makerslide.com/
3 Aluminium 2040 profile 180mm 1 [5]
4 Aluminium 2040 profile 380mm 1 [6]
5 Stepper motor for X, Y and E axes NEMA 17 3
6 Stepper motor with threaded rod for Z axes NEMA 17 2
7 Controller board RAMPS 1.4 + MEGA 2560 R3 + 5 x A4988 Driver + 3 x Endstop + USB Cable 1
8 Hot end JHead 0.35mm 1.75mm v5b 1
9 Delrin V-wheels Comes with makerslides 14 [7] from http://makerslide.com/
10 Power Supply 12v 10A 120W 1
11 Bed - Acrylic 250mm (L) x 250mm (W) x 5mm (T) (Smoked Brown with C5 chamfered edges) 1 [8]
12 Bed Backing - Acrylic 240mm (L) x 240mm (W) x 10mm (T) with 3x thread-insert holes 1 [9]
13 Extrusion Gear MK7 Stainless Steel for 1.75mm Filament 1
14 Flanged bearings FL625ZZ ID5.0 OD16.0 B5.0 with flange on one side 10
15 Open belt 2GT 1220 1.11m
16 Pulley 2GT 20T 2
17 PTFE tube ID2mm OD4mm 0.92m
18 Grooved ball bearing for extruder V625ZZ 1
19 Cooling Fan for hotend 40x40x10 12V, >7cu.ft./min , <25dBA 1
20 Cooling Fan for electronics 40x40x20 12V, >7cu.ft./min , <25dBA 1
21 Pushfit connector for 4mm tubing 1
22 Caphead screw M5x16 (Head Dia 8.7 && Head Height 5.0) 16
23 Caphead screw M5x20 (Head Dia 8.7 && Head Height 5.0) 4
24 Caphead screw M5x25 (Head Dia 8.7 && Head Height 5.0) 3
25 Bed levelling Springs OD10 L15 3
26 Extruder Spring OD10 L10 1
27 Big washers ID5.0 OD>16.0 T2.0 3
28 Small washers ID5.0 OD10.0 T1.0 6
29 High temp wire for heater 2m
30 High temp wire for thermistor 2m
31 Cable tie 20
32 Spiral wire wrap 0.32m
Printed Parts List
S/N Item description Quantity Image
1 Cornerjoints 1 pair
cornerjoints
2 yguide 1 pair
yguide
3 plusmount_guide_wheelcap 1
wheelcap
4 plusmount_guide_wheel 1
wheel
5 plusmount_connector_clips 4
plusmount_connector
6 frameconnector_snap 1
snap
7 frameconnector_perpendicular 1
frameconnector
8 bedlevel_frontmount 1
frontmount
frontmount
9 bedlevel_mount 2
mount
10 bedlevel_knob 3
knob
11 frameend 1 pair
frameend
12 idler_mount 1
idler_mount
13 hotend_head 1
hotend_head
14 head_vent 1
vent
15 8to4_tubeadapter 1
adaptor
16 endstop_mount 1
endstop_mount
17 Sidextruder 1
Sidextruder
18 ramps_box 1
ramps_box
Building instructions
Assembly manual v4.2 [10]
Video
Sid printing the endstop mounts <videoflash type="youtube">-42Da7UAPzM</videoflash>
Contact us
For any queries, please email weiin[AT]simplifi3d[DOT]asia
