Sid
Revision as of 23:33, 7 August 2016 by Simplifi3D (talk | contribs) (Video: removed dead link)
Sid Documentation
Sid
A printer designed for education. No screws required for structural components
Thingiverse [1], Youmagine [2]
Sid was designed by Prad Lal (https://www.behance.net/pradlal) of Blokko and Simplifi3D (http://www.simplifi3d.asia) for education. No screws are required for the assembly of structural components.
Project Goal
Designed as an educational printer kit that even a 9-year old can put together in 2 hrs.
Overview
The linear motion is based on Barton Dring's Makerslide. This printer was designed to be built with no tools by using slots and clips for connecting the various parts.
  • Build volume: 100 (L) x 100 (W) x 100 (H) mm
  • Printer Size (when assembled): 400 (L) x 350 (W) x 290 (H) mm
  • Power input: 110-240V 50-60Hz
  • Nozzle size: 0.35mm
  • Filament diameter: 1.75mm
  • Material: PLA
  • Controller: RAMPS 1.4
  • Firmware: Repetier-Host
Non-printed Parts List
S/N Item description Specifications Quantity Remarks
1 Makerslide 240mm 2 [3] from http://makerslide.com/
2 Makerslide 250mm 2 [4] from http://makerslide.com/
3 Aluminium 2040 profile 180mm 1 [5]
4 Aluminium 2040 profile 380mm 1 [6]
5 Stepper motor for X, Y and E axes NEMA 17 3
6 Stepper motor with threaded rod for Z axes NEMA 17 2
7 Controller board RAMPS 1.4 + MEGA 2560 R3 + 5 x A4988 Driver + 3 x Endstop + USB Cable 1
8 Hot end JHead 0.35mm 1.75mm v5b 1
9 Delrin V-wheels Comes with makerslides 14 [7] from http://makerslide.com/
10 Power Supply 12v 10A 120W 1
11 Bed - Acrylic 250mm (L) x 250mm (W) x 5mm (T) (Smoked Brown with C5 chamfered edges) 1 [8]
12 Bed Backing - Acrylic 240mm (L) x 240mm (W) x 10mm (T) with 3x thread-insert holes 1 [9]
13 Extrusion Gear MK7 Stainless Steel for 1.75mm Filament 1
14 Flanged bearings FL625ZZ ID5.0 OD16.0 B5.0 with flange on one side 10
15 Open belt 2GT 1220 1.11m
16 Pulley 2GT 20T 2
17 PTFE tube ID2mm OD4mm 0.92m
18 Grooved ball bearing for extruder V625ZZ 1
19 Cooling Fan for hotend 40x40x10 12V, >7cu.ft./min , <25dBA 1
20 Cooling Fan for electronics 40x40x20 12V, >7cu.ft./min , <25dBA 1
21 Pushfit connector for 4mm tubing 1
22 Caphead screw M5x16 (Head Dia 8.7 && Head Height 5.0) 16
23 Caphead screw M5x20 (Head Dia 8.7 && Head Height 5.0) 4
24 Caphead screw M5x25 (Head Dia 8.7 && Head Height 5.0) 3
25 Bed levelling Springs OD10 L15 3
26 Extruder Spring OD10 L10 1
27 Big washers ID5.0 OD>16.0 T2.0 3
28 Small washers ID5.0 OD10.0 T1.0 6
29 High temp wire for heater 2m
30 High temp wire for thermistor 2m
31 Cable tie 20
32 Spiral wire wrap 0.32m
33 Fan extension wire 0.67m Optional
Printed Parts List
S/N Item description Quantity Image
1 Cornerjoints 1 pair
cornerjoints
2 yguide 1 pair
yguide
3 plusmount_guide_wheelcap 1
wheelcap
4 plusmount_guide_wheel 1
wheel
5 plusmount_connector_clips 4
plusmount_connector
6 frameconnector_snap 1
snap
7 frameconnector_perpendicular 1
frameconnector
8 bedlevel_frontmount 1
frontmount
frontmount
9 bedlevel_mount 2
mount
10 bedlevel_knob 3
knob
11 frameend 1 pair
frameend
12 idler_mount 1
idler_mount
13 hotend_head 1
hotend_head
14 head_vent 1
vent
15 8to4_tubeadapter 1
adaptor
16 endstop_mount 1
endstop_mount
17 Sidextruder 1
Sidextruder
18 ramps_box 1
ramps_box
Building instructions
Assembly manual v4.2 [10]
Repetier firmware [11]
Contact us
For any queries, please email weiin[AT]simplifi3d[DOT]asia
