SpatialOne
Revision as of 15:25, 4 May 2016 by Andornot (talk | contribs)
SpatialOne
filament mixing delta printer.
ShareAlike Creative Commons V3 (CC-BY-NC-SA 3.0)
All information of this page was taken from SpatialOne source files.
SpatialOne is a fused filament fabrication 3D Delta printer designed for robustness and accuracy of the moving parts. A kit with manufactured sheetmetal and machined parts, powered by a smoothie board with industrial bearings.
One of its unique feature is to have an interchangeable end effector, currently with a single hot end, further developments such as dual extruder, chocolate printer, Laser etching, flexible filament printing and ceramic printer. 12 way plug and socket for easy swap between different end effectors.
This page is a work-in-progress and will be updated soon.
Specification
Print Technology: Fused filament fabrication (FFF)
Print Media: PLA, ABS, Nylon, etc any material with extrusion temperature up to 300C except flexible filament (new extruder and hot end platform to print such materials coming soon)
Build Volume: 270mm diameter x 300mm height (diameter and height varies depending on single or dual hot ends or different platform designs)
Layer Resolution: 0.1mm to 0.4mm
Filament Diameter: 1.75mm
Extrusion Speed: Travel speeds of 500mm/s and print speeds up to 300mm/s.
Materials: Anodised aluminium, aluminium, 304 stainless steel, zinc plated mild steel, pla printed parts
Construction: Robust metal construction, cnc laser cut sheetmetal parts and cnc machined parts with some printed parts. E3d Online v6 hot end, all metal extruder with stepper and gearbox. Moving Parts: Preloaded ball raced vertical slides to eliminate any adjustment required and play. Igus rod ends and misumi industrial bearings.
Electronics: Smoothie board 5xc, capable of dual extruders, with GLCD graphic controller, can be run standalone or via usb cable.
Firmware: Smoothieware
AC input: 100-240VAC 50-60Hz
Power Requirements: 24VDC @ 500w and (12VDC @ 15w, Meanwell this may change as cooling system is investigated) power supplies. Connectivity: USB and Ethernet.
Auto levelling: Aluminium heated bed with FSR levelling, FSR levelling z probe to increase accuracy and consistency. Auto levelling of the bed using calibration functions built into the smoothie board and auto z height set before each print.
Interchangeable End Effector: Interchangeable end effector, currently with a single hot end, further developments such as dual extruder, chocolate printer, Laser etching, flexible filament printing and ceramic printer. 12 way plug and socket for easy swap between different end effectors.
Where to buy
The lit is available on kickstarter until 1 june 2016 link: Kickstarter SpatialOne
The kit is available from SpatialOne Kit
